jpoplawski Tue, 09/02/2008 - 12:44
  • Bronze, 100 points or more
Diane,
No you can go directly to 8.0.3, just verify that you meet the correct specs and you should be good to go. Also, make sure you update ASDM as well. As always, backup your configuration before proceeding.
JB
dianewalker Tue, 09/02/2008 - 14:18
Thanks for your prompt response. I downloaded the new image. What command do I tell ASA to load the new image?
Thanks.
Diane
debra-brown Tue, 09/02/2008 - 19:57
Diane
Type the following command:
boot system disk0:/configfilename
Please note that there are no spaces between disk0: and "/" and "configfilename". The "configfilename" is the file that you just downloaded.
After typing the above command, don't forget to reboot the device.
Good luck.
