Locked out of LMS 3
Hi, I have LMS 3 on Windows Server 2003 with the December 2007 patch.
I enabled SSL CsicoWorks session so that it will use HTTPS instead of HTTP.
When I try to login with ADMIN user account I received:
FORFIDDEN You don't have permission to access /cwhp/LiaisonServlet on this server.
I was able to login just fine before this change!
How can I reset LMS to a previous configuration?
Joe Clarke Tue, 09/02/2008 - 15:12
I don't know. It sounds like you're using the wrong URL, you have changed your service startup parameters, or SSL was not properly enabled. You can try runing ConfigSSL.pl again with the -enable argument to re-enable SSL.
