convert wav to g711
Sep 2nd, 2008
I used to use the MOH translator on CCM to do this, but no on cm5.x and 6.x there is no way to download the translated file. How and what can I use to convert my wav to g711 for CVP?
1 vote
Overall Rating: 5 (1 ratings)
Chad Stachowicz Tue, 09/02/2008 - 22:03
I used dbPowerAmp Music Converter and it seems to work great.
channels mono
8bit sampling
done :)
tim.giles Wed, 09/03/2008 - 02:22
You should be able to do this via Windows sound recorder (START > Programs > Accessories > Entertainment > Sound Recorder).
Just open up the file and then choose Save As. There is a "format" option where you can change the compression etc.
I've used this for Unity recordings before and it works fine. No need to download additional software either.
Please rate useful posts....
alpersakarya Sun, 02/17/2013 - 11:28
How are you changing it to
I am looking details of CCA's sound recorder and then setting it the way you mention here but
dbPowerAmp Music Converter still converts as Lossless now Lossy.
Where is the ulaw setting?
Also tim.giles for some reason my Windows Sound Recorder only allows .wma resordings even I click on dropdown to save as other options.
Do you click on something else once you hit stop after recording?
What happened is I had the speaker record my prpompts in WMA not WAV so  I am running in to this now.
