1841 SEC K9 with HWIC-2FE
bashan121
Hi!
Is it possible to use the HWIC-2FE module into the 1841 SEC/K9 bundle? Using the online Cisco Dynamic config tool, HWIC-2FE is not listed as an option when you select the 1841. Does it mean that this configuration won't work? Thanks very much for your help!
Jon Marshall
Unfortunately the 1841 does not support the HWIC-2FE module. It only supports the HWIC-1FE module. See attached link for more details -
http://www.cisco.com/en/US/docs/routers/access/interfaces/ic/hardware/installation/guide/fe_hwic.html#wp1049748
Jon
Jon Marshall
Jon
Hi Jon!
Thanks very much for the useful link, you answered my inquiry authoritatively. On the side though, I have another question regarding the HWIC-1FE. Using the config tool, after choosing the 1841 SEC K9, it won't allow me to choose the HWIC-1FE unless I change the IOS to one that doesn't have crypto, why is that? Who would want to use an IOS without crypto? Thanks very much again for your help.
