LMS 3.1 Baseline Templates: Auditing a policy-map and/or class-map?
Sep 2nd, 2008
Has anyone arrived at a working method to audit the contents of a policy-map or class-map using baseline templatesb? I've tried to treat these as ordered-lists much like an ACL, but have not been met with much success (The compliance-check returns non-compliant on a switch with the appropriate commands in the proper order)
Example:
Name: PMMOAccessPolicing SubMode: Yes isPrerequisite: No
Ordered : Yes Prerequisite-Commandset : none Parent: none
policy-map PM-MO_ACCESS_POLICING
+ class CM-VOICE
+ set dscp ef
+ class CM-INTERACTIVE_VIDEO
+ set dscp af41
+ police 5000000 8000 exceed-action policed-dscp-transmit
+ class CM-STREAMING_VIDEO
+ set dscp cs4
+ class CM-CALL_SIGNALING
+ set dscp cs3
+ class CM-IP_ROUTING
+ class CM-NETWORK_MANAGEMENT
+ set dscp cs2
+ class CM-MISSION_CRITICAL
+ set dscp af31
+ class CM-TRANSACTIONAL
+ set dscp af21
+ class CM-BULK
+ set dscp af11
+ class class-default
+ set dscp default
-Jeremy
Joe Clarke Wed, 09/03/2008 - 11:54
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
These commands contain sub-commands, and you can't simply evaluate them all at the same level.
That is, under policy-map PM-NO_ACCESS_POLICING, when you enter class CM-VOICE, you enter another submode. Your baseline needs to descend into that submode to check for set dscp ef. You can do this with a child template under the main parent.
Each subsequent class could also be a child of main parent template.
