How Can I "Physically" Integrate MHSRP or GLBP?
Sep 2nd, 2008
I have an edge router with a few serial, ISDN and a T1 hanging off of it. I want to put a second router online and enable MHSRP or GLBP. I can't seem to see how I could bring a second router online unless I deploy an inline switch but that would leave me a single point of failure. Any ideas?
Overall Rating: 2 (2 ratings)
Calin Chiorean Wed, 09/03/2008 - 00:35
  • Silver, 250 points or more
Hi there!
Sorry but I don't understand what you want to do (maybe others don't understand too, because there are no answers here).
You have a router (R1, the existing one) and you want to add another router (let's say R2) and you connect them together via an ethernet line. Than you can do a L3 HSRP or GLBP between them.
You have below a sample config with HSRP:
R1:
interface GigabitEthernetx/y
ip address 1.1.1.2 255.255.255.248
duplex auto
speed auto
standby 1 ip 1.1.1.1
standby 1 priority 110
standby 1 preempt
R2:
ip address 1.1.1.3 255.255.255.248
duplex auto
speed auto
and use the standby ip for all the communications.
Sorry if I didn't understood what do you need.
Cheers,
Calin
Joseph W. Doherty Wed, 09/03/2008 - 03:38
Ideas to avoid single point of failure, yes. For your switch, you use one that offers redundancy, e.g. chassis with multiple line card blades and reduncant components; or reduncancy via. stack of switches, e.g. 3750/3750-E series; or two switches that are interconnected. If the latter, you might have access/edge switchs with an uplink to each "core" switch, and run spanning tree. (NB: you often still have single point of failure at the edge, but that can be addressed with multiple links from hosts to different edge switches or blades on a chassis.)
