Webview Historical reports not working
This a new install were everything works fine webview works good for real-time but for historical report is gives me "ODBC connection failed" in Jaguar I do see an similar error log in failed to HDS. I checked the login account and sql and dont see any issue there.
Some of the post was suggesting changing the SQL date format in PBODB--.ini file tried that with out luck.
Has any one had this problem and resolved it?
Reg/OS
khambetea Thu, 09/04/2008 - 03:28
Did you try to go to ODBC and test the connection?
-Anjali
