how to setup back-to-back ADSL connection
Sep 2nd, 2008
I'm a student in networking field, and then I come out with my project title which to demonstrate the alternate backup link using ADSL technology. The problem is, I don't know how to setup the ADSL physical connection using end to end connection (router to router).Because I want to show and demonstrate the backup function. For this simulation, the dedicated v.35 (DCE and DTE) with 2 MB speed operate like leased line (primary line). How about the secondary line which is ADSL connection?
For this demonstration, the primary link is dedicated v.35 DCE&DTE acts as a leased line. While I want to use ADSL as backup link (secondary link).The question is how to setup ADSL connection as backup connection (secondary link)?
Really want help.
For information, see the attachment.
Overall Rating: 4.3 (3 ratings)
Marwan ALshawi Wed, 09/03/2008 - 01:49
with adsl u need only normal fasethernet port
see this link but this link loadbalnce the traffic
if u want the adsl as backup only
just on the default route that point to the adsl increas the metric
for example
if u have seriel interface primary and adsl dialer interface back up u could have these static routes
ip route 0.0.0.0 0.0.0.0 interface serial0
ip route 0.0.0.0 0.0.0.0 interface dialer0 5
the 5 mean the metric default for static route is 1 so the first route through the seril interface will be used if down the second one will be considered thorugh the dialer0 over adsl
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_configuration_example09186a0080950834.shtml
good luck
if helpful Rate
azizigman Wed, 09/03/2008 - 02:04
Hi marwanshawi thanks for the reply.
My problem is how to built the adsl connection first?
Connection type,cable type,hardware type.
The file attach is my own thinking.I don't know weither it runnig or not,can modem to modem communnicate?
Marwan ALshawi Wed, 09/03/2008 - 02:20
ok
sorry because i dint read all ur post
first adsl to adsl can be done trough the internet
but each router or at least one router need to have static IP
and the connection should be over VPN
so for ur simulation u can use normal fasethernet or ethernet as the adsl over internet connection the idea same but u gonna simulate it only
but over internet u need static ip address fron the service provider and u can build the connection thorugh vpn
adsl comes over telephon network the ISP after u subsecribe with them they give u user name password and modem the modem has to connections one gose to the telephon line and the other is normal rj45 ethernet gose to ur router
the connection known as pppoe
or pppoa
http://www.cisco.com/en/US/products/hw/routers/ps2167/products_configuration_example09186a0080093fcf.shtml
this link provide u details about vpn with adsl example
http://www.cisco.com/en/US/tech/tk583/tk372/technologies_configuration_example09186a008009475c.shtml
this link for adsl modem with cisco router setup
http://www.cisco.com/en/US/docs/routers/access/800/836/hardware/quick/guide/836QSG_ps380_TSD_Products_Installation_Guide.html
this one as well
http://www.cisco.com/en/US/docs/routers/access/800/826/hardware/quick/guide/826QSGED.html
good luck
if helpful Rate
azizigman Wed, 09/03/2008 - 02:36
for my demonstration to demonstrate the adsl as secondary link, it's can only be done trough the internet?If i don't to subscribe?
because i only want to demonstrate it.
Marwan ALshawi Wed, 09/03/2008 - 02:45
as i told u use normal ethernet cable from router to router as directly connected
which simulate a backup link
this link in real lif coud be adsl,cable modem or whatever link
the impotrtant think in ur demonstration is to show the primary link and the redundant back up link
good luck :)
azizigman Wed, 09/03/2008 - 02:53
if i using normal ethernet cable as directly connected to simulate backup link using adsl, it is can show the adsl technology,function? because my issue is to used adsl to replace isdn as backup link.
Marwan ALshawi Wed, 09/03/2008 - 02:58
no it will not show
but as a real life with adsl u gonna use ethernet and u configure dialer interface as u seen it in the links i sent u
so actualy it will be similer but not exactly
the same
