CUCM 7.0(1)
Sep 3rd, 2008
Is CUCM 7.0(1) available for pruchase? If so then I would apparetiate any help for the product version number and hardware compatiblity matrix. I have been informed that it was released last week but cannot find any information. Only thing I can find is the Features, Admin, System guide and the SRND.
Thanks for taking the time.
Overall Rating: 4.5 (2 ratings)
Chris Deren Tue, 09/09/2008 - 08:29
CM 7 may be ordarable, but it is not shipping yet, latest I've heard was Sep 24th.
Jason Nash Tue, 02/03/2009 - 03:36
We too have MCS-7835-H1-IPC1 servers. I can see that the following document lists these servers as being compatible with the 7.0 release. Altough these servers only have two 72GB drives in a RAID 1+0 configuration. I might be wrong but starting from version 7.0 do you not require 146GB drives? Can anyone confirm?
rob.huffman Tue, 02/03/2009 - 05:24
Hi Jason,
I have not heard of that requirement :) Here is a note from the CUCM 7.x Release Notes;
Note Be aware that some servers that are listed in the Cisco Unified Communications Manager Software Compatibility Matrix may require additional hardware support for Cisco Unified CM Release 7.0(1). Make sure that your server meets the minimum hardware requirements, as indicated in the footnotes of the Cisco Unified Communications Manager Software Compatibility Matrix. Cisco Unified CM requires a minimum of 2 GB of memory, 72 GB disk drive, and 2 GHz processor.
Hope this helps!
Jason Nash Tue, 02/03/2009 - 05:34
Thanks Rob! This is good to know, I must have been given incorrect info.
joh.aicher Wed, 02/04/2009 - 09:29
Hi Jason,
Cisco comes this week with CUCM 7.0(2)
Best. Reg.
georgediavatis Fri, 02/20/2009 - 01:25
Is "CM7.0-K9-DL380 SW only, CUCM 7.0 for HP DL380-G4/5- 1CPU or 7835-H2/H3" the correct part code for upgrading a 7835-H1-IPC1 server to CM7.0? thanks
Ayodeji oladipo... Fri, 02/20/2009 - 02:50
According to cisco's documentation, the
HP DL380-G4 Server is equivalent to the MCS 7835-H1 and the HP DL380-G4 is equivalent to MCS 7835-H2. So with you having a 7835-H1-IPC1, I will say certainly the CM7.0-K9-DL380 SW only is correct part number
