Can't get site-to-site VPN working
Answered Question
Sep 3rd, 2008
Hi. I'm trying to get a site-to-site VPN to work between a Pix 515 (running 7.2) and a Cisco 1801 integrated services router (configs attached). Basically the tunnel will not come up. The 1801 was not configured by myself and I'm unfamiliar with it's functions, though I have remote access to it.
1801 network is - WAN 86.47.179.237/30, LAN 128.70.0.0/24.
Pix n/w is - WAN - 194.159.238.98, LAN - 10.10.29.0/24.
I suspect a config issue on the 1801 as i've configured the pix many times before without issue.
If it helps, the only syslog messages I can find relating to the 1801 is
2008-09-03 09:38:42	Local4.Info	10.10.29.1	%PIX-6-302020: Built ICMP connection for faddr 86.47.179.237/0 gaddr 194.159.238.98/0 laddr 194.159.238.98/0
2008-09-03 09:38:42	Local4.Info	10.10.29.1	%PIX-6-302021: Teardown ICMP connection for faddr 86.47.179.237/0 gaddr 194.159.238.98/0 laddr 194.159.238.98/0
Any help would be greatly appreciated.
Rex
Correct Answer by jpoplawski about 8 years 7 months ago
On the PIX remove the PFS statement:
no crypto map crypto_mdc_outside 100 set pfs
On the Router remove the PFS statement
crypto map SDM_CMAP_1 1 ipsec-isakmp
no set pfs group2
write mem, reload both and see if that prevails.
check some debugs
PIX
debug crypto isakmp 255
show crypto isakmp sa
debug crypto ispec 255
show crypto ipsec sa
RTR
debug crypto isakmp
debug crypto ispec
Also a helpful guide I've used previously would be http://cisco.com/en/US/products/ps6120/products_tech_note09186a00807e0aca.shtml#pfs
That covers the previously mentioned pfs reference earlier as well.
HTH,
JB
Overall Rating: 5 (3 ratings)
grant.maynard Wed, 09/03/2008 - 03:14
  • Silver, 250 points or more
A tomcat error is preventing me from downloading the configs. Could you post the following parts:
isakmp ...
ipsec ....
crypto ...
plus any vpn ACLs
Rex Biesty Wed, 09/03/2008 - 05:25
Thanks for the reply. COnfig from Pix is
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto dynamic-map cryptod_mdc_outside 5 set transform-set ESP-3DES-MD5
crypto map crypto_mdc_outside 20 match address outside_20_cryptomap
crypto map crypto_mdc_outside 20 set peer Metalogic_Warwick_Public
crypto map crypto_mdc_outside 20 set transform-set ESP-3DES-MD5
crypto map crypto_mdc_outside 20 set security-association lifetime seconds 86400
crypto map crypto_mdc_outside 40 match address outside_40_cryptomap
crypto map crypto_mdc_outside 40 set peer 217.155.130.97
crypto map crypto_mdc_outside 40 set transform-set ESP-3DES-MD5
crypto map crypto_mdc_outside 60 match address outside_60_cryptomap
crypto map crypto_mdc_outside 60 set pfs
crypto map crypto_mdc_outside 60 set peer 81.144.184.37
crypto map crypto_mdc_outside 60 set transform-set ESP-3DES-SHA
crypto map crypto_mdc_outside 80 match address outside_80_cryptomap
crypto map crypto_mdc_outside 80 set pfs
crypto map crypto_mdc_outside 80 set peer 217.41.116.53
crypto map crypto_mdc_outside 80 set transform-set ESP-3DES-SHA
crypto map crypto_mdc_outside 100 match address outside_100_cryptomap
crypto map crypto_mdc_outside 100 set peer 86.47.179.237
crypto map crypto_mdc_outside 100 set transform-set ESP-3DES-SHA
crypto map crypto_mdc_outside 65535 ipsec-isakmp dynamic cryptod_mdc_outside
crypto map crypto_mdc_outside interface outside
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
crypto isakmp policy 20
encryption 3des
hash md5
group 2
lifetime 86400
crypto isakmp policy 30
encryption des
hash sha
group 2
lifetime 86400
crypto isakmp policy 40
encryption des
hash md5
group 2
lifetime 86400
crypto isakmp ipsec-over-tcp port 10000
tunnel-group mih-remote type ipsec-ra
tunnel-group mih-remote general-attributes
address-pool VPN_Pool
default-group-policy mih-remote
tunnel-group mih-remote ipsec-attributes
pre-shared-key *
tunnel-group 62.69.58.233 type ipsec-l2l
tunnel-group 62.69.58.233 ipsec-attributes
pre-shared-key *
tunnel-group 217.155.130.97 type ipsec-l2l
tunnel-group 217.155.130.97 ipsec-attributes
pre-shared-key *
tunnel-group 81.144.184.37 type ipsec-l2l
tunnel-group 81.144.184.37 ipsec-attributes
pre-shared-key *
tunnel-group 217.41.116.53 type ipsec-l2l
tunnel-group 217.41.116.53 ipsec-attributes
pre-shared-key *
tunnel-group Northgate-Support type ipsec-ra
tunnel-group Northgate-Support general-attributes
address-pool Northgate_Pool
tunnel-group Northgate-Support ipsec-attributes
pre-shared-key *
tunnel-group Epicore_Support type ipsec-ra
tunnel-group Epicore_Support general-attributes
address-pool Epicor_Pool
tunnel-group Epicore_Support ipsec-attributes
pre-shared-key *
tunnel-group Pulsion_Support type ipsec-ra
tunnel-group Pulsion_Support general-attributes
address-pool Pulsion_Pool
tunnel-group Pulsion_Support ipsec-attributes
pre-shared-key *
tunnel-group 86.47.179.237 type ipsec-l2l
tunnel-group 86.47.179.237 ipsec-attributes
pre-shared-key *
tunnel-group Hytemp_Support type ipsec-ra
tunnel-group Hytemp_Support general-attributes
address-pool Hytemp_Pool
tunnel-group Hytemp_Support ipsec-attributes
pre-shared-key *
Rex Biesty Wed, 09/03/2008 - 05:31
Thanks. I'm not sure what you mean by pfs. Could you elaborate please?
Rex Biesty Wed, 09/03/2008 - 05:26
ACLs from Pix is
access-list outside_100_cryptomap extended permit ip 10.10.29.0 255.255.255.0 128.70.0.0 255.255.255.0
access-list acl_mdc_inside_nat0 extended permit ip 10.10.29.0 255.255.255.0 128.70.0.0 255.255.255.0
Rex Biesty Wed, 09/03/2008 - 05:28
COnfig from 1801
encr 3des
group 2
crypto isakmp key Cybert00l address 194.159.238.98 no-xauth
crypto ipsec transform-set atg ah-sha-hmac esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-3DES-SHA1 esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-3DES-SHA2 esp-3des esp-sha-hmac
description Tunnel to194.159.238.98
set peer 194.159.238.98
set pfs group2
match address 103
archive
log config
hidekeys
track 1 rtr 1 reachability
interface FastEthernet0
description $ES_LAN$
no ip address
shutdown
duplex auto
speed auto
interface BRI0
description $BACKUP_INTF_ATM0.1_TRACK_1$
no ip address
encapsulation ppp
dialer pool-member 1
isdn switch-type basic-net3
isdn point-to-point-setup
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
interface FastEthernet5
interface FastEthernet6
interface FastEthernet7
interface FastEthernet8
interface ATM0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
pvc 8/35
pppoe-client dial-pool-number 2
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-FE 1$
ip address 128.70.0.254 255.255.255.0
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1412
interface Dialer0
ip address 159.134.114.180 255.255.255.0
ip nat outside
encapsulation ppp
dialer pool 1
dialer string 1893252525
dialer-group 1
no cdp enable
ppp authentication chap callin
ppp chap hostname austin09
ppp chap password 0 eircom1
interface Dialer1
ip address 86.47.179.237 255.255.255.252
ip mtu 1452
ip nat outside
encapsulation ppp
dialer pool 2
dialer-group 2
no cdp enable
ppp chap hostname eircom
ppp chap password 0 broadband1
ip local policy route-map SDM_BACKUP_RMAP_1
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer1 track 1
ip route 0.0.0.0 0.0.0.0 Dialer0 2
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source route-map SDM_RMAP_1 interface Dialer0 overload
ip nat inside source route-map nonat interface Dialer1 overload
ip sla 1
icmp-echo 194.159.238.98 source-interface Dialer1
timeout 1000
threshold 2
frequency 3
ip sla schedule 1 life forever start-time now
access-list 100 remark SDM Backup Route-Map ACL
access-list 100 remark SDM_ACL Category=1
access-list 100 permit icmp any host 194.159.238.98 echo
access-list 101 remark SDM_ACL Category=16
access-list 101 permit ip 128.70.0.0 0.0.0.255 10.10.29.0 0.0.0.255
access-list 102 remark SDM_ACL Category=18
access-list 102 remark IPSec Rule
access-list 102 deny ip 128.70.0.0 0.0.0.255 10.10.29.0 0.0.0.255
access-list 102 permit ip 128.70.0.0 0.0.0.255 any
access-list 103 remark SDM_ACL Category=4
access-list 103 remark IPSec Rule
access-list 103 permit ip 128.70.0.0 0.0.0.255 10.10.29.0 0.0.0.255
dialer-list 1 protocol ip permit
dialer-list 2 protocol ip permit
no cdp run
Correct Answer
jpoplawski Thu, 09/04/2008 - 06:04
  • Bronze, 100 points or more
no set pfs group2
check some debugs
PIX
RTR
debug crypto isakmp
debug crypto ispec
HTH,
JB
Rex Biesty Thu, 09/04/2008 - 07:39
Thanks for the reply. Removing pfs resolved the issue and all working fine now.
