Add vlan on a trunk
claude1968
Hello
If my trunk is in use between two switch, if I use the add command to add another vlan allowed in the trunk, Is there a cutoff network?
5 Replies 5
Calin C.
Level 5
Level 5
Hello Claude!
Use:
"switchport trunk allowed vlan add x"
and you will have no outage there.
Good luck!
Cheers,
Calin
Thanks a lot.
The addition "add" of a vlan in a trunk does not cut the networking of others vlan allowed in the trunk. Is Cisco has documented this because I found no documentation about that?
claude1968,
From what i interpreted, your question is "if I use the add command to add another vlan allowed in the trunk, Is there a cutoff network?
If you dont have the switchport trunk allowed vlan [vlan-id]command already enable on your trunk and you add that command, you will block all other vlans except the vlan you are allowing.
If you already have the switchport trunk allowed vlan [vlan-id] command and add another vlan then yes you will not block any other vlan in the list.
Francisco.
That's perfect. Thanks.
francisco_1
Level 7
Level 7
by default, all vlans allowed on the trunk link so yes you will because you are limiting the vlan allowed on the trunk. only the vlan you allowed with the "switchport trunk allowed vlan [vlan-id]" command will work on the trunk link.
use the "switchport trunk allowed vlan [vlan-id]" comamnd on both switches to permit the vlans on the trunk link
