Allocating memory modules in routers
nicolas.matzick
sometimes I have the problem to determine faulty memory modules.
For example in a 12000 series router i have 2x1GB modules installed on the PRP-2. Now I get a memory error, this time one module is just missing (router reports only 1GB, schould have 2GB).
How can I determine which module is working and which is the faulty one ?
Is there a command that reports how the module (PRP) is fitted ?
Thanks for your help,
best regards,
Nico
aghaznavi
Level 5
Level 5
In order to determine the faulty memory module in routers, it is essential that you collect the output from these commands:
show context summary
show logging
show logging summary
show diag
show context slot
