Client VPN cannot see the remote pcs
Sep 3rd, 2008
I have a problem with the VPN connection.I am connecting asa5520 and client vpn software. VPN connection is up. Problem is that i can only ping one remote pc. I was just using the wizard to set up the connection.attached is the running config. Help is very much appreciated.
regards,
cempuerto
bamnocadmin Wed, 09/03/2008 - 06:47
Can you be more specific on that IP you are trying to ping from what subnet?
I see you are assigning IPs to VPN Clients from 10.10.3.0/24, but you have /28 network in split tunnel ACL.
Thanks.
acomiskey Wed, 09/03/2008 - 07:05
  • Green, 3000 points or more
You can also get rid of this...
no access-list test_splitTunnelAcl_1 standard permit 10.10.3.48 255.255.255.240
cempuerto Wed, 09/03/2008 - 14:20
i try this once i get to the office.thanks alot for sharing your time on this concern
cempuerto Thu, 09/04/2008 - 14:43
i have removed this line "access-list test_splitTunnelAcl_1 standard permit 10.10.3.48 255.255.255.240". still no changes..any other suggestion??
cempuerto Wed, 09/03/2008 - 14:16
i am trying to ping 10.10.1.0 network. i was able to ping 10.10.1.4 but the rest of the pc and gateway.i could not.by the way i have set up a site to site and remote server vpn using the same asa5520.i dont have problems pinging from the otherside.if i am fro 1.0 netwrk i can ping the pc from network 3.0
singhsaju Fri, 09/05/2008 - 09:23
  • Silver, 250 points or more
Are you able to ping ASA's inside interface?
It looks to me a routing issue rather than configuration issue. Check routing for remote subnet in the network .
Can you post result of "show crypto ipsec sa" ?
Saju
