Setting ring duration before call goes to voicemail
mmonteiro11
Does anyone know how to set the ring duration on a specific phone before call goes to voicemail?
We are using CME 3.2 and we have 7940 series IP phones.
Thanks in advance for your help.
Marwan ALshawi
You may define how long a phone can ring with no answer before returning disconnect tone to the caller. This timeout is used only for extensions that do not have call-forward-no-answer (CFNA) configured
telephony-service
timeouts ringing 120
if u have forward to voice mail do the following
ephone-dn 2 dual-line
call-forward noan [voicemail number]timeout 10
change the 10 to whatever number u want
good luck
if helpful rate
I am a bit confused. The extension forwards to voicemail, so do I need to set both "timeouts ringing" and "call-forward noan [voicemail number]timeout"?
Hi mmonteiro11,
telephony-service
- THE ABOVE IS A TELEPHONY SERVICE COMMAND TO BE SET TO ALL PHONES. THIS COMMAND SETS THE PHONE TO RING FOR X SECOND OR IN THIS CASE 120 SECONDS. YOU SHOULDN'T NEED THIS THOUGH.
- THIS COMMAND SET'S THE NO ANWSER TIMEOUT TO 10 AFTER 10 SECONDS THE CALL WILL FORWARD TO VOICEMAIL. THIS COMMAND SHOULD BE THE ONLY ONE YOU NEED.
HTH, Please rate if so.
Justin
hi there based on the commands i sent u just change the
so that u can decreas tyhe seconds or ringing befor the call forwarded to ur voice mail
ok :)
if helpful rate
