ASA 55xx license bundles
Answered Question
Sep 3rd, 2008
I'm looking at different 5505 and 5505 bunldes. One is licensed for 10 users (pretty cheap), the other one is licensed for 50 users (considerably more expensive). My question is - what do those numbers actually mean? Is this the limit of users that can be configured in the AAA authentication mechanism or does the ASA check how many IPs are connected to it?
Thanks!
Correct Answer by Richard Burts about 8 years 6 months ago
Jack
In case the previous responses were not quite explicit, you can configure as many users as you wish. The limit that the ASA imposes is the number of devices connected at the same time.
Rick
Correct Answer by grant.maynard about 8 years 6 months ago
The ASA tracks IP addresses on its inside.
Correct Answer by francisco_1 about 8 years 6 months ago
for example if you purchase 10 user bundle licenses, it means that the ASA can only build xlate connection (allow connection) for only 10 ip addresses and no more.
i suggest you go for
ASA 5505 Unlimited User Software license - ASA5505-SEC-BUN-K8.
Overall Rating: 4.7 (3 ratings)
Correct Answer
francisco_1 Wed, 09/03/2008 - 06:36
  • Gold, 750 points or more
Correct Answer
grant.maynard Wed, 09/03/2008 - 09:06
  • Silver, 250 points or more
Correct Answer
Richard Burts Wed, 09/03/2008 - 10:11
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Jack
Rick
