Change Unity Connection IP
testeven Wed, 09/03/2008 - 08:41
  • Cisco Employee,
Hi!
You need to access the CLI interface of your Unity Connection server (using a SSH client) and use the following command:
set network ip eth0
After that, you will need to reboot the Unity Connection server for the change to take effect.
Hope this helps! :)
Tere.
