09-03-2008 07:11 AM
I have a VIP that is not able to stream RTSP over UDP. TCP streaming works fine, but when I configure UDP on the Real client no UDP packets are even processed by the ACE.
When I configure 'inspect rtsp' on the class, then TCP streaming also breaks. I am using A2.10.
Anyone got any hints on where I am going wrong ?
Greg
class-map match-all stream._rtsp554_vip
2 match virtual-address 10.216.35.75 tcp eq rtsp
class-map match-all stream._udp6970_vip
2 match virtual-address 10.216.35.75 udp eq 6970
policy-map type loadbalance first-match stream._rtsp554_vip-l7slb
class class-default
serverfarm stream._rtsp554_sfarm
policy-map type loadbalance first-match stream._udp6970_vip-l7slb
class class-default
serverfarm stream._UDP_sfarm
class stream._rtsp554_vip
loadbalance vip inservice
loadbalance policy stream._rtsp554_vip-l7slb
loadbalance vip icmp-reply active
nat dynamic 1598 vlan 1598
class stream._tcp8080_vip
loadbalance policy stream._tcp8080_vip-l7slb
class stream._udp6970_vip
loadbalance policy _udp6970_vip-l7slb
Solved! Go to Solution.
09-03-2008 09:05 AM
I have never got a chance to play with ACE + RTSP over UDP but
As per
ACE supports RTSP over TCP Loadbalanacing only.
Similarly for RTSP Inspection its clearly stated at
For RTSP inspection
The ACE supports TCP only in conformity with RFC 2326.
Syed Iftekhar Ahmed
09-03-2008 09:05 AM
As per
For RTSP inspection
Syed Iftekhar Ahmed
