H264 support - CCM4.2
Answered Question
Sep 3rd, 2008
Hi, I have a CCM4.2(3)SR2b installation with several Tandberg (H323) and VTA (2.1) endpoints.
VTA to VTA is fine negotiating an H264 codec. Unfortunately the best I can get with the Tanndberg H323 endpoints is H263. I know CCM 4.1.3 introduced H264 support for SCCP endpoints. Does anyone know if there is supposed to be H264 support for H323 endpoints. The Tandberg endpoints are created within CCM as H323 devices. The tandberg endpoints have the IP address of the CallManager server for H225/245, ie they do not use a gatekkeper.
I'm having no luck getting H264 working between
Correct Answer by Jaime Valencia about 8 years 9 months ago
unfortunately the support for h264 is limited to sccp to sccp calls, there is no support for it with h323
Take a look at the system guide for 4.2(3) here:
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide_chapter09186a008070e4ea.html
In the Video Codec section, you see:
"The system supports H.264 for calls that use skinny Client Control Protocol (SCCP) on originating and terminating endpoints only."
java
if this helps, please rate
Overall Rating: 5 (2 ratings)
Correct Answer
Jaime Valencia Fri, 09/05/2008 - 13:55
  • Cisco Employee,
  • Hall of Fame,
    2011
java
hauchinango Tue, 05/12/2009 - 04:50
Anyone know if this is still the case with CUCM 6.1? Looking to do H264 between H323 and SCCP devices.
Jaime Valencia Tue, 05/12/2009 - 05:23
  • Cisco Employee,
  • Hall of Fame,
    2011
Linux appliances do support h264 between h323 and sccp
java
