Unable to establish l2l because of mismatched attr.
Sep 3rd, 2008
We are trying to connect a l2l between a 515e and VPN concentrator using 3DES-SHA. We are getting the following error information from the concentrator:
IKEDBG/79 RPT=1603304 Proposal #1, Transform #1, Type ESP, Id Triple-DES Parsing received transform: Phase 2 failure: Mismatched attr types for class Encapsulation: Rcv'd: UDP-Encapsulated-Tunnel Cfg'd: Tunnel
I am not sure how to change the UDP-Encapsulated to just Tunnel.
Overall Rating: 5 (1 ratings)
bamnocadmin Wed, 09/03/2008 - 09:32
hello,
It's defiantly ISAKMP problem. Check you NAT-T on PIX - no crypto isakmp nat-traversal
Thanks.
jsehlhorst Tue, 09/09/2008 - 07:39
It worked! but can you please explain how it fixed the issue and if that change will impact anything else?
Jerry Sehlhorst
