IOS and Syslog-NG
Sep 3rd, 2008
I have been trying to setup logging via tcp on syslog-ng. all the messages come in fine via udp, but when i configure a tcp source, assign it to the syslog-ng target, etc, then configure the router, i don't get any events. i can see the packets coming in via tcp dump, but syslog-ng won't collect anything. am i missing something. my logging config is below....
logging buffered 4096 informational
logging origin-id hostname
logging source-interface Serial1.1
logging host 192.168.101.150 transport tcp port 5014
jtalbaugh Wed, 09/03/2008 - 08:10
Possibly the logging trap command. This can be set to several different levels so set to what best suits your needs.
an example of my basic config below:
logging on
logging #.#.#.#
logging source-interface Loopback0
logging trap notificati
drummond.r Wed, 09/03/2008 - 08:38
doesn't seem to help; here is the output from a show log:
Syslog logging: enabled (1 messages dropped, 0 messages rate-limited,
0 flushes, 0 overruns, xml disabled, filtering disabled)
Console logging: disabled
Monitor logging: level debugging, 0 messages logged, xml disabled,
filtering disabled
Buffer logging: level informational, 117 messages logged, xml disabled,
filtering disabled
Logging Exception size (4096 bytes)
Count and timestamp logging messages: disabled
No active filter modules.
Trap logging: level notifications, 173 message lines logged
Logging to 192.168.101.153(global) (tcp port 5014, audit disabled, link up), 4 message lines logged, xml disabled,
filtering disabled
