Cisco 878 Router in G.SHDSL Config
Answered Question
Sep 3rd, 2008
I want to use 2 Cisco 878 routers to extend my LAn to a location where I have copper only. I know I can use the G.SHDSL port in back to back configuration but don't know how to set it up.
CAn anyone help me
Mike Williams
Correct Answer by andrew.prince@m... about 8 years 5 months ago
The cable specs are here:-
http://www.cisco.com/en/US/prod/collateral/modules/ps5949/ps7175/prod_qas0900aecd80591ff1.html
70% down the page, then just cross pins 3 & 4 at one end.
HTH>
Overall Rating: 5 (1 ratings)
michael.m.williams Wed, 09/03/2008 - 08:52
Andrew,
based on this the setting for the port are set to auto config. The connection is RJ-11 on the back of the 878, would you know how to make 2 878 talk over the G.SHDSL port. It comes with a purple RJ-11 ccable, but van't find the pinouts anywhere. This is new tech for me.
mike
michael.m.williams Fri, 09/05/2008 - 09:12
Andrew,
I now have the two 878 connected and I get a CD LED, and I see both atm0 and dsl are up. here is the problem.
When I am consoled in I can telnet or ping both routers. Router one is connected via FE0 to network, I can ping and telnet to both ATM and VLAN interfaces on router 1, but I can not see ATM0 or VLAn interface on router 2. I have enabled EIGRP and inputted static routes but still can not talk or pass data.
Any ideas?
Mike
michael.m.williams Fri, 09/05/2008 - 10:26
Here are the configs.
ITSCR3SRK2 is connected to my network on fa 1
and connected to STDTBRT01 via the ATMO (G.SHDSL) port. Like I said when I am consoled in to ITSCR3RT01 I can ping 100.100.100.2 on the STDTBRT01. I also tried to do a show ip eigrp neighbor on STDTBRT01 but it didn't see the other router.
mike
andrew.prince@m... Fri, 09/05/2008 - 12:19
Michael,
Can you post the output on both routers:-
show ip eigrp nei
show ip eigrp interface
show ip eigrp topology
andrew.prince@m... Sat, 09/06/2008 - 02:14
Looks like the routers do not like passing the EIGRP multicast frames over the SDSL. I think you have 2 options:-
1) Create GRE tunnels, and encapsulate EIGRP into the tunnel over the SDSL.
2)Only use the ATM interfaces for the layer2 connectivity - and use the dialer interface for all IP communications encapsulating into PPP.
HTH>
michael.m.williams Mon, 09/08/2008 - 06:34
I got a step closer and can now talk to the ATM interface on the remote router.
I turned on debug ATM error and notice I was getting an "Encapsulation error1, link=7, host xxxxx"
So I found that I needed to add the broadcast command under interface ATM0
PVC 8/35
protocol ip 100.100.100.1 broadcast. This now is allowing me to ping the interface on remote router and router are exchanging hello packets and seeing eachother, now I am trying to pass Vlans and set up the management vlan in vlan 50, set up VTP domians on both routers but I can not talk to the management IP on the remote router. I have configured a vlan trunk on port fa 3 of the local router. I can not talk to the management side of the remote router.
mike
andrew.prince@m... Mon, 09/08/2008 - 07:50
Mike,
You are tyring to pass layer 2 information over a layer 3 link, that is not IEEE 802.3 - this you cannot do.
If you want to "route" between the VLAN's at the two seperate ends - you need a layer 3 interface for inter-vlan routing.
See the below links:-
http://www.cisco.com/en/US/tech/tk389/tk815/technologies_configuration_example09186a008015f17a.shtml
http://www.cisco.com/en/US/tech/tk389/tk815/technologies_configuration_example09186a00800949fd.shtml
HTH>
