Need help for IOS upgradiation
Sep 3rd, 2008
I am planning to upgrade the IOS in 2950 for the same i have verified the flash in my flash showing two IOS. But its booted with one IOS with out boot system command .
How switch will choose the IOS means based on which parameters??
SW#sh flash
Directory of flash:/
2 -rwx 1674921 Apr 30 2001 15:09:51 c2950-c3h2s-mz.120-5.3.WC.1.bin
4 drwx 10176 Jan 01 1970 00:00:19 html
5 -rwx 660 Mar 31 1993 04:34:36 vlan.dat
165 -rwx 284 Jan 01 1970 00:17:26 env_vars
166 -rwx 2774747 Mar 07 2003 20:45:37 c2950-i6q4l2-mz.121-12c.EA1.bin
167 -rwx 4812 May 28 1993 18:32:45 config.text
168 -rwx 47 May 28 1993 18:32:45 private-config.text
sateesh
Overall Rating: 5 (1 ratings)
Edison Ortiz Wed, 09/03/2008 - 09:53
Whichever it finds first in the flash:
Per your output, it will boot from c2950-c3h2s-mz.120-5.3.WC.1.bin as its listed first.
Don't let the switch pick from the list and use the boot system flash command in the configuration. Any reason for not doing so?
__
Edison.
vaisharm Wed, 09/03/2008 - 10:09
Hi Sateesh
Without a boot statement, by default the switch/router would pick the first file in the flash to boot the device. If the first file is not a valid IOS image bin file, the device would drop into ROMMON or boot mode depending on the platform.
HTH~
Vaibhav
sateeshk10 Wed, 09/03/2008 - 10:14
Thanks for info..
But it took second file..how come??
As per the flash IOs seems to be ok and suppose to take first one...right??
sateesh
Edison Ortiz Wed, 09/03/2008 - 11:38
Yes, it's supposed to take the first one. Please post the running-config along with the show boot output.
__
Edison.
johnnykman Wed, 09/03/2008 - 11:47
On a CCIE blog, there was a similar question for a 3750 switch. I'm sure the same logic applies here. Enter the command show boot on your switch. You should see a BOOT path-list entry. This probably will have both IOS files listed. They had used the "archive download-sw" command to add the new IOS to flash and found that one of the default settings is; The BOOT environment variable is changed to point to the new software image on the flash: file system.
John
sateeshk10 Wed, 09/03/2008 - 12:11
pls find below the required details..
sh run attached...
SwW#sh boot
BOOT path-list: flash:c2950-i6q4l2-mz.121-12c.EA1.bin
Config file: flash:config.text
Private Config file: flash:private-config.text
Enable Break: no
Manual Boot: no
HELPER path-list:
NVRAM/Config file
buffer size: 32768
Edison Ortiz Wed, 09/03/2008 - 14:54
Your boot statement contains the file so a 'search' in the flash: system isn't made.
Perhaps it's not showing in the running configuration because the set boot command was used instead of the boot system command.
See:
http://www.cisco.com/en/US/docs/switches/lan/catalyst2950/software/release/12.1_22ea/CR/bootldr.html#wp1004653
HTH,
__
Edison.
Please rate helpful posts
arupbiet2006 Thu, 09/04/2008 - 00:42
1st one is help to boot ur router...u can delete the flash and then install new ios in your router
