Warning message
7937 with CUCM6.12
Rob Huffman Thu, 09/04/2008 - 05:54
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Ken,
Don't know if this helps at all but I just wanted to let you know that the Corporate Directory is working on a 7937 that I just tested (not on CCM 6.1(2)) It did not come up on the initial "Directories screen" as it is choice # 5 so you have to scroll down a bit.
Hope this helps!
Rob
ssbarnett Mon, 09/08/2008 - 07:37
Hi guys we are seeing the same thing, the 7937 seems to use a diffrent browser from the standard phone, it also looks like it times out. The phone software is on 1.2(1) and the bootrom is 1.0. Was going to check if there where any firmware updates. will update once i have checked.
We are also on 6.1(2)
