CM6 and VG200s
Sep 3rd, 2008
Hi all. I'm just wondering if a VG200 can be used as an H323 gateway with CallManager 6. I would think that with H323 the model wouldn't matter at all.
Anyone know for sure?
Overall Rating: 5 (1 ratings)
Jaime Valencia Wed, 09/03/2008 - 11:41
VG224 can be configured for H323, MGCP and SCCP, VG248 is only SCCP
just found the link:
•Lower cost of ownership-The Cisco VG200 communicates with the Cisco CallManager using the Media Gateway Control Protocol (MGCP) or H.323 Version 2. It allows connectivity between a Cisco CallManager-based IP telephony system and legacy telephony equipment such as the PSTN, private branch exchanges (PBXs), and voice-mail systems. The Cisco VG200 provides a space-saving solution that can be managed remotely using network management applications such as CiscoWorks.
as you mention, CUCM version is really not relevant.
if this helps, please rate
