SSL VPN Question
Sep 3rd, 2008
The network topology i have in-house is:
Internet --- Router(T1) --- ASA --- Internal Network. I'm natting on the router and ASA.
My question are:
Is it possible to get a SSL VPN is set up to outside interface of T1? If so, how?
Or, is a site-2-site possible with the ASA being the termination point with other remote ASA.
-K
Marwan ALshawi Wed, 09/03/2008 - 20:58
about T1 havnt tried it with webvpn
but check if u can crypto map or enable webvpn on it if u able then it is possible
about ASA site to site u can and if u do nating the rotuer u just need static nat PAT or nat for ports isakmp or udp 500 and esp
to the asa outside interface from the t1 public ip interface
good luck
if helpful Rate
