Jaime Valencia Wed, 09/03/2008 - 10:53
CDR records, if you can make a call now use some debugs
otherwise look at a CUCM trace
java
if this helps, please rate
rcrumm_2 Wed, 09/03/2008 - 12:20
Hi The calls were made 15:00 local time in China so I just need to check to see if the calls came through my local gw
can't I do it through cdr reports?
Randall
Jaime Valencia Wed, 09/03/2008 - 13:45
yes, i did mention them in my previous post in case you missed that
java
