PGW CLIR override
Sep 3rd, 2008
Hi there!
I have a pgw installation, there are SS7 connections to PSTN, and SIP connections to user's PBXs. Every SIP destination has an own dialplan. When an IAM arrives from SS7, on some SIP dialplans I have to override the optional CLIR setting. I found the string, it's called CG_PRES_IND under resulttable, but I cannot use this to override the presentation indication setting from IAM. Is somebody can to explain me, how can I make this config step by step?
Thanks in advance
zskadar Wed, 09/03/2008 - 11:20
Hello Daniel,
We are using as call controller (switched mode).
zskadar Wed, 09/03/2008 - 11:50
Yes, I saw this document, but I tried to search the solution int the dialplan. The trunkgroups are maintained globally, we want to override the CLIR setting per dialplan (sip destination based on B-num), not on all.
