VG224 voice-port "not registered"
Sep 3rd, 2008
  • Gold, 750 points or more
I have a VG224 integrated to CCM with SCCP. I noticed that a voice-port is not registered, but all the others are registered.
I tried reseting the analog phone from CCM, shut/no shut under dial-peer pots, erasing the dial-peer at all, but registration is unsuccessful. I did a debug sccp events, debug sccp messages to see if there is an output when performing a shut/no shut of the dial-peer but I don't see any output.
Can I assume that the voice-port is completely damaged?
- Adrián.
Overall Rating: 5 (1 ratings)
Steellllllllll0 Wed, 09/03/2008 - 12:06
You tried shut/no shut under the port or perhaps a reboot altogether ?
t.a.bennett Thu, 09/04/2008 - 04:35
Whats a 'show voice-port summ' show up, config matching other ports (i.e. service stcapp), try shut no shut the port on VG224 with sccp debug running.
moataz_mamdouh Wed, 03/05/2014 - 07:48
I am facing the same problem , is reloading the gateway can solve the problem ?
moataz_mamdouh Wed, 03/05/2014 - 07:49
attahced my show version
show ver
Cisco IOS Software, vg224 Software (vg224-I6K9S-M), Version 15.1(4)M3, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Tue 06-Dec-11 21:44 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T7, RELEASE SOFTWARE (fc1)
KIETDAG001 uptime is 3 weeks, 19 hours, 36 minutes
System returned to ROM by reload
System image file is "slot0:vg224-i6k9s-mz.151-4.M3.bin"
Last reload type: Normal Reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
Cisco VG224 (R527x) processor (revision 4.1) with 119808K/11264K bytes of memory.
Processor board ID FGL152813Z6
R527x CPU at 225MHz, Implementation 40, Rev 3.1
1 On-Board Twenty-Four FXS Analog Voice Module V2.1
2 FastEthernet interfaces
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity disabled.
63K bytes of non-volatile configuration memory.
System fpga version is 250027
System readonly fpga version is 250027
Option for system fpga is 'system'.
62720K bytes of ATA Slot0 CompactFlash (Read/
Carlo Poggiarelli Wed, 03/05/2014 - 08:07
  • Green, 3000 points or more
Hi.
Which version of CUCM are you running?
Let me know
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Carlo Poggiarelli Wed, 03/05/2014 - 08:22
Hi.
Try a no ccm-manager sccp and ccm-manager sccp to re-register all ports
Carlo
moataz_mamdouh Wed, 03/05/2014 - 08:25
This command is not working because we ate not using sccp auto configuration
Carlo Poggiarelli Wed, 03/05/2014 - 08:49
Hi.
Can you please activate a debug sccp all an post the output?
Carlo
moataz_mamdouh Wed, 03/05/2014 - 10:38
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2014.03.05 20:36:45 =~=~=~=~=~=~=~=~=~=~=~=
000772: *Mar 22 22:23:59.093 UTC: sccp_generate_msg: msg_id 0 msg_len 4 pak_size 12
000773: *Mar 22 22:23:59.093 UTC: sccp_send_keep_alive_msg_v1: send keepalive id 0, len 4
000774: *Mar 22 22:23:59.093 UTC: SCCP(AND0FD4A4961406)send KeepAliveMessage to ccm identifier 2
000775: *Mar 22 22:23:59.093 UTC: sccp_transmit_msg: sending on socket 5
000776: *Mar 22 22:23:59.093 UTC: sccp_queue_msg_to_xmit:Enqueued sccp msg,size 12, socket 5, profile_id 0
000777: *Mar 22 22:23:59.093 UTC: sccpapp_process_send_sccpmsg_q: Send sccp msg from sccp_msg_send_q, soc 5,  pak size 12
KIETDAG001(config-voiceport)#
000778: *Mar 22 22:23:59.097 UTC: sccp_send_msg_nonblocking: Sccp message sent socket 5, profile_id 0, sent bytes 12, total pak_size 12, bytes_to_send 12
000779: *Mar 22 22:23:59.145 UTC: sccpapp_process_socket_events: appl_type 4, soc_fd 5, soc 5, swb_soc -1
000780: *Mar 22 22:23:59.145 UTC: sccpapp_process_socket_events: TCP_SOCKET_READ: appl_type 4, eve 4, state 6
000781: *Mar 22 22:23:59.145 UTC: sccp_get_control_message: bytes_to_read 8, bytes_read 8, appl_total_bytes 8, appl_bytes_read 8, soc_read_mode 0, soc 5
000782: *Mar 22 22:23:59.145 UTC: sccp_get_control_message: bytes_to_read 4, bytes_read 4, appl_total_bytes 4, appl_bytes_read 4, soc_read_mode 1, soc 5
000783: *Mar 22 22:23:59.149 UTC: sccp_get_control_message: sccp cntl msg rcvd, prof_id 0, appl_type 4, msg_len 4
000784: *Mar 22 22:23:59.149 UTC: sccp_parse_control_msg: msg_ptr 63DC8AA0, msg_len 4, msg_id 256
000785: *Mar 22 22:23:59.149 UTC: sccp_parse_control_msg: glob_ccm->version 9
000786: *Mar 22 22:23:59.149 UTC: SCCP(AND0FD4A4961406)rcvd KeepAliveAckMessage from ccm identifier 2
000787: *Mar 22 22:24:03.757 UTC: sccp_generate_msg: msg_id 0 msg_len 4 pak_size 12
000788: *Mar 22 22:24:03.757 UTC: sccp_send_keep_alive_msg_v1: send keepalive id 0, len 4
000789: *Mar 22 22:24:03.757 UTC: SCCP(AND0FD4A4961400)send KeepAliveMessage to ccm identifier 2
000790: *Mar 22 22:24:03.757 UTC: sccp_transmit_msg: sending on socket 0
000791: *Mar 22 22:24:03.757 UTC: sccp_queue_msg_to_xmit:Enqueued sccp msg,size 12, socket 0, profile_id 0
000792: *Mar 22 22:24:03.757 UTC: sccpapp_process_send_sccpmsg_q: Send sccp msg from sccp_msg_send_q, soc 0,  pak size 12
000793: *Mar 22 22:24:03.761 UTC: sccp_send_msg_nonblocking: Sccp message sent socket 0, profile_id 0, sent bytes 12, total pak_size 12, bytes_to_send 12
000794: *Mar 22 22:24:03.809 UTC: sccpapp_process_socket_events: appl_type 4, soc_fd 0, soc 0, swb_soc -1
000795: *Mar 22 22:24:03.809 UTC: sccpapp_process_socket_events: TCP_SOCKET_READ: appl_type 4, eve 4, state 6
000796: *Mar 22 22:24:03.809 UTC: sccp_get_control_message: bytes_to_read 8, bytes_read 8, appl_total_bytes 8, appl_bytes_read 8, soc_read_mode 0, soc 0
000797: *Mar 22 22:24:03.813 UTC: sccp_get_control_message: bytes_to_read 4, bytes_read 4, appl_total_bytes 4, appl_bytes_read 4, soc_read_mode 1, soc 0
000798: *Mar 22 22:24:03.813 UTC: sccp_get_control_message: sccp cntl msg rcvd, prof_id 0, appl_type 4, msg_len 4
000799: *Mar 22 22:24:03.813 UTC: sccp_parse_control_msg: msg_ptr 65DB9AF8, msg_len 4, msg_id 256
000800: *Mar 22 22:24:03.813 UTC: sccp_parse_control_msg: glob_ccm->version 9
000801: *Mar 22 22:24:03.813 UTC: SCCP(AND0FD4A4961400)rcvd KeepAliveAckMessage from ccm identifier 2
KIETDAG001(config-voiceport)#no
000802: *Mar 22 22:24:05.745 UTC: sccpapp_process_socket_events: appl_type 4, soc_fd 5, soc 5, swb_soc -1
000803: *Mar 22 22:24:05.745 UTC: sccpapp_process_socket_events: TCP_SOCKET_READ: appl_type 4, eve 4, state 6
000804: *Mar 22 22:24:05.745 UTC: sccp_get_control_message: bytes_to_read 8, bytes_read 8, appl_total_bytes 8, appl_bytes_read 8, soc_read_mode 0, soc 5
000805: *Mar 22 22:24:05.745 UTC: sccp_get_control_message: bytes_to_read 16, bytes_read 16, appl_total_bytes 16, appl_bytes_read 16, soc_read_mode 1, soc 5
000806: *Mar 22 22:24:05.745 UTC: sccp_get_control_message: sccp cntl msg rcvd, prof_id 0, appl_type 4, msg_len 16
000807: *Mar 22 22:24:05.745 UTC: sccp_parse_control_msg: msg_ptr 63DC8AA0, msg_len 16, msg_id 131
000808: *Mar 22 22:24:05.745 UTC: sccp_parse_control_msg: glob_ccm->version 9
000809: *Mar 22 22:24:05.745 UTC: SCCP(AND0FD4A4961406)rcvd StopToneMessage
000810: *Mar 22 22:24:05.745 UTC: StopToneMsg Info:
    line: 1, call_ref: 246215025
000811: *Mar 22 22:24:05.749 UTC: sccpapp_process_socket_events: appl_type 4, soc_fd 5, soc 5, swb_soc -1
000812: *Mar 22 22:24:05.749 UTC: sccpapp_process_socket_events: TCP_SOCKET_READ: appl_type 4, eve 4, state 6
000813: *Mar 22 22:24:05.749 UTC: sccp_get_control_message: bytes_to_read 8, bytes_read 8, appl_total_bytes 8, appl_bytes_read 8, soc_read_mode 0, soc 5
000814: *Mar 22 22:24:05.749 UTC: sccp_get_control_message: bytes_to_read 20, bytes_read 20, appl_total_bytes 20, appl_bytes_read 20, soc_read_mode 1, soc 5
000815: *Mar 22 22:24:05.749 UTC: sccp_get_control_message: sccp cntl msg rcvd, prof_id 0, appl_type 4, msg_len 20
000816: *Mar 22 22:24:05.749 UTC: sccp_parse_control_msg: msg_ptr 63DC8AA0, msg_len 20, msg_id 272
000817: *Mar 22 22:24:05.749 UTC: sccp_parse_control_msg: glob_ccm->version 9
000818: *Mar 22 22:24:05.749 UTC: SCCP(AND0FD4A4961406)rcvd SelectSoftKeys
000819: *Mar 22 22:24:05.753 UTC: sccpapp_process_socket_events: appl_type 4, soc_fd 5, soc 5, swb_soc -1
000820: *Mar 22 22:24:05.753 UTC: sccpapp_process_socket_events: TCP_SOCKET_READ: appl_type 4, eve 4, state 6
000821: *Mar 22 22:24:05.753 UTC: sccp_get_control_message: bytes_to_read 8, bytes_read 8, appl_total_bytes 8, appl_bytes_read 8, soc_read_mode 0, soc 5
000822: *Mar 22 22:24:05.753 UTC: sccp_get_control_message: bytes_to_read 16, bytes_read 16, appl_total_bytes 16, appl_bytes_read 16, soc_read_mode 1, soc 5
000823: *Mar 22 22:24:05.753 UTC: sccp_get_control_message: sccp cntl msg rcvd, prof_id 0, appl_type 4, msg_len 16
000824: *Mar 22 22:24:05.753 UTC: sccp_parse_control_msg: msg_ptr 63DC8AA0, msg_len 16, msg_id 131
000825: *Mar 22 22:24:05.753 UTC: sccp_parse_control_msg: glob_ccm->version 9
000826: *Mar 22 22:24:05.753 UTC: SCCP(AND0FD4A4961406)rcvd StopToneMessage
000827: *Mar 22 22:24:05.753 UTC: StopToneMsg Info:
000828: *Mar 22 22:24:05.757 UTC: sccpapp_process_socket_events: appl_type 4, soc_fd 5, soc 5, swb_soc -1
000829: *Mar 22 22:24:05.757 UTC: sccpapp_process_socket_events: TCP_SOCKET_READ: appl_type 4, eve 4, state 6
000830: *Mar 22 22:24:05.757 UTC: sccp_get_control_message: bytes_to_read 8, bytes_read 8, appl_total_bytes 8, appl_bytes_read 8, soc_read_mode 0, soc 5
000831: *Mar 22 22:24:05.757 UTC: sccp_get_control_message: bytes_to_read 172, bytes_read 172, appl_total_bytes 172, appl_bytes_read 172, soc_read_mode 1, soc 5
000832: *Mar 22 22:24:05.757 UTC: sccp_get_control_message: sccp cntl msg rcvd, prof_id 0, appl_type 4, msg_len 172
000833: *Mar 22 22:24:05.757 UTC: sccp_parse_control_msg: msg_ptr 63DC8AA0, msg_len 172, msg_id 261
000834: *Mar 22 22:24:05.761 UTC: sccp_parse_control_msg: glob_ccm->version 9
000835: *Mar 22 22:24:05.761 UTC: SCCP(AND0FD4A4961406)rcvd OpenReceiveChannel
000836: *Mar 22 22:24:05.761 UTC: OpenReceviceChannel msg rcvd in hex -
5 1 0 0 71 F1 AC E 57 74 A E 14 0 0 0 B 0 0 0 0 0 0 0 0 0 0 0 71 F1 AC E 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 A FB 80 36 0 0 0 0 0 0 0 0 0 0 0 0 A0 F 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
000837: *Mar 22 22:24:05.769 UTC: OpenReceiveChannelMsg Info:
conference_id = 246215025, pass_through_party_id = 235566167
msec_pkt_size = 20, compression_type = 11
qualifier_in.ecvalue = 0, g723_bitrate = 0, call_ref = 246215025
stream_pass_through_id = 0, rfc2833_payload_type = 0
codec_dynamic_payload = 0, codec_mode = 0
Encryption Info :: algorithm_id 0, key_len 0, salt_len 0
requestedAddrType = 0, source_ip_addr.ipAddrType = 0, source_ip_addr = 10.251.128.54, source_port_number = 4000,
audio_level_adjustment = 0
000838: *Mar 22 22:24:05.769 UTC: v150 latent caps NOT ative
000839: *Mar 22 22:24:05.769 UTC:  sccp_dcapi_extract_and_validate_srtp_context
000840: *Mar 22 22:24:05.769 UTC: sccp_spi_orc_ack: enqueue spi evt SCCP_SPI_MEDIA_ORC_ACK, reg_name=AND0FD4A4961406
000841: *Mar 22 22:24:05.773 UTC: sym_xapp_process_ccapi_events: minor is ZERO - should be non-zero for CCAPI event
000842: *Mar 22 22:24:05.773 UTC: sccp_generate_msg: msg_id 34 msg_len 40 pak_size 48
000843: *Mar 22 22:24:05.773 UTC: sccp_open_receive_channel_ack_v14: going to send ack to CCM - status 0, ipaddr 10.250.41.198, port 16746, conn_id 235566167, prof_id 0
000844: *Mar 22 22:24:05.773 UTC: sccp_open_receive_channel_ack_v14: OpenRecvChnlAck msg txed in hex(including header) - len 48
000845: *Mar 22 22:24:05.773 UTC: sccp_print_hex_msg: Len:48 Hex:
28 00 00 00 15 00 00 00 22 00 00 00 00 00 00 00 00 00 00 00 0A FA 29 C6 24 8D 40 02 63 FB 6F 5D 50 10 FF FF 6A 41 00 00 57 74 0A 0E 71 F1 AC 0E
000846: *Mar 22 22:24:05.773 UTC: sccp_transmit_msg: sending on socket 5
000847: *Mar 22 22:24:05.773 UTC: sccp_queue_msg_to_xmit:Enqueued sccp msg,size 48, socket 5, profile_id 0
000848: *Mar 22 22:24:05.773 UTC: sccpapp_process_send_sccpmsg_q: Send sccp msg from sccp_msg_send_q, soc 5,  pak size 48
000849: *Mar 22 22:24:05.777 UTC: sccp_send_msg_nonblocking: Sccp message sent socket 5, profile_id 0, sent bytes 48, total pak_size 48, bytes_to_send 48
000850: *Mar 22 22:24:05.797 UTC: sccpapp_process_socket_events: appl_type 4, soc_fd 5, soc 5, swb_soc -1
000851: *Mar 22 22:24:05.797 UTC: sccpapp_process_socket_events: TCP_SOCKET_READ: appl_type 4, eve 4, state 6
000852: *Mar 22 22:24:05.797 UTC: sccp_get_control_message: bytes_to_read 8, bytes_read 8, appl_total_bytes 8, appl_bytes_read 8, soc_read_mode 0, soc 5
000853: *Mar 22 22:24:05.797 UTC: sccp_get_control_message: bytes_to_read 172, bytes_read 172, appl_total_bytes 172, appl_bytes_read 172, soc_read_mode 1, soc 5
000854: *Mar 22 22:24:05.797 UTC: sccp_get_control_message: sccp cntl msg rcvd, prof_id 0, appl_type 4, msg_len 172
000855: *Mar 22 22:24:05.797 UTC: sccp_parse_control_msg: msg_ptr 63DC8AA0, msg_len 172, msg_id 138
000856: *Mar 22 22:24:05.797 UTC: sccp_parse_control_msg: glob_ccm->version 9
000857: *Mar 22 22:24:05.797 UTC: SCCP(AND0FD4A4961406)rcvd StartMediaTransmission
000858: *Mar 22 22:24:05.797 UTC: StartMediaTrans msg rcvd in hex -
8A 0 0 0 71 F1 AC E 57 74 A E 0 0 0 0 A FB 80 36 0 0 0 0 0 0 0 0 0 0 0 0 B0 64 0 0 14 0 0 0 B 0 0 0 B8 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 71 F1 AC E 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
000859: *Mar 22 22:24:05.805 UTC: StartMediaTransmissionMsg Info:
remote_ip_addr = 10.251.128.54, remote_port = 25776
qualifier_out.precedence_value = 184, qualifier_out.ssvalue = 0
qualifier_out.max_frames_per_pkt = 0, g723_bitrate = 0, call_ref = 246215025, stream_pass_through_id = 0 rfc2833_payload_type = 0
Encryption Info :: algorithm_id 0, key_len 0salt_len 0
000860: *Mar 22 22:24:05.809 UTC: v150 latent caps NOT ative
000861: *Mar 22 22:24:05.809 UTC:  sccp_dcapi_extract_and_validate_srtp_context
000862: *Mar 22 22:24:05.829 UTC: sccpapp_process_socket_events: appl_type 4, soc_fd 5, soc 5, swb_soc -1
000863: *Mar 22 22:24:05.829 UTC: sccpapp_process_socket_events: TCP_SOCKET_READ: appl_type 4, eve 4, state 6
000864: *Mar 22 22:24:05.829 UTC: sccp_get_control_message: bytes_to_read 8, bytes_read 8, appl_total_bytes 8, appl_bytes_read 8, soc_read_mode 0, soc 5
000865: *Mar 22 22:24:05.829 UTC: sccp_get_control_message: bytes_to_read 88, bytes_read 88, appl_total_bytes 88, appl_bytes_read 88, soc_read_mode 1, soc 5
000866: *Mar 22 22:24:05.829 UTC: sccp_get_control_message: sccp cntl msg rcvd, prof_id 0, appl_type 4, msg_len 88
000867: *Mar 22 22:24:05.829 UTC: sccp_parse_control_msg: msg_ptr 63DC8AA0, msg_len 88, msg_id 330
000868: *Mar 22 22:24:05.829 UTC: sccp_parse_control_msg: glob_ccm->version 9
000869: *Mar 22 22:24:05.829 UTC: SCCP(AND0FD4A4961406)rcvd CallInfoV2Message
000870: *Mar 22 22:24:05.829 UTC: CallInfoV2Msg Info:
    calling party name:         VoIP Gateway for Pharma-Port6
    called party name:
    calling party:              86901221
    called party:
    line instance:              1
    call reference:             246215025
    call type:                  2
    orig called pty name:
    orig called pty:
KIETDAG001(config-voiceport)#n     last redirecting pty name:
    last redirecting pty:
    orig cdpn redirect reason:  0
    last redirect reason:       0
    cgpn voice mailbox:
    cdpn voice mailbox:
    orig cdpn voice mailbox:
    last redirectvoice mailbox:
    call instance:              1
    call security status:       1
    pres restriction bits:      0
KIETDAG001(config-voiceport)#no shu
KIETDAG001(config-voiceport)#no shutdown
000871: *Mar 22 22:24:08.265 UTC: %LINK-3-UPDOWN: Interface Foreign Exchange Station 2/2, changed state to up
000872: *Mar 22 22:24:09.577 UTC: sccp_generate_msg: msg_id 0 msg_len 4 pak_size 12
000873: *Mar 22 22:24:09.577 UTC: sccp_send_keep_alive_msg_v1: send keepalive id 0, len 4
000874: *Mar 22 22:24:09.577 UTC: SCCP(AND0FD4A4961401)send KeepAliveMessage to ccm identifier 2
000875: *Mar 22 22:24:09.577 UTC: sccp_transmit_msg: sending on socket 1
000876: *Mar 22 22:24:09.577 UTC: sccp_queue_msg_to_xmit:Enqueued sccp msg,size 12, socket 1, profile_id 0
000877: *Mar 22 22:24:09.577 UTC: sccp_generate_msg: msg_id 0 msg_len 4 pak_size 12
000878: *Mar 22 22:24:09.577 UTC: sccp_send_keep_alive_msg_v1: send keepalive id 0, len 4
000879: *Mar 22 22:24:09.577 UTC: SCCP(AND0FD4A4961405)send KeepAliveMessage to ccm identifier 2
000880: *Mar 22 22:24:09.577 UTC: sccp_transmit_msg: sending on socket 2
000881: *Mar 22 22:24:09.577 UTC: sccp_queue_msg_to_xmit:Enqueued sccp msg,size 12, socket 2, profile_id 0
000882: *Mar 22 22:24:09.581 UTC: sccpapp_process_send_sccpmsg_q: Send sccp msg from sccp_msg_send_q, soc 1,  pak size 12
000883: *Mar 22 22:24:09.581 UTC: sccp_send_msg_nonblocking: Sccp message sent socket 1, profile_id 0, sent bytes 12, total pak_size 12, bytes_to_send 12
000884: *Mar 22 22:24:09.581 UTC: sccpapp_process_send_sccpmsg_q: Send sccp msg from sccp_msg_send_q, soc 2,  pak size 12
000885: *Mar 22 22:24:09.581 UTC: sccp_send_msg_nonblocking: Sccp message sent socket 2, profile_id 0, sent bytes 12, total pak_size 12, bytes_to_send 12
000886: *Mar 22 22:24:09.633 UTC: sccpapp_process_socket_events: appl_type 4, soc_fd 1, soc 1, swb_soc -1
000887: *Mar 22 22:24:09.633 UTC: sccpapp_process_socket_events: TCP_SOCKET_READ: appl_type 4, eve 4, state 6
000888: *Mar 22 22:24:09.633 UTC: sccp_get_control_message: bytes_to_read 8, bytes_read 8, appl_total_bytes 8, appl_bytes_read 8, soc_read_mode 0, soc 1
000889: *Mar 22 22:24:09.633 UTC: sccp_get_control_message: bytes_to_read 4, bytes_read 4, appl_total_bytes 4, appl_bytes_read 4, soc_read_mode 1, soc 1
000890: *Mar 22 22:24:09.633 UTC: sccp_get_control_message: sccp cntl msg rcvd, prof_id 0, appl_type 4, msg_len 4
000891: *Mar 22 22:24:09.633 UTC: sccp_parse_control_msg: msg_ptr 65D0CB14, msg_len 4, msg_id 256
000892: *Mar 22 22:24:09.633 UTC: sccp_parse_control_msg: glob_ccm->version 9
000893: *Mar 22 22:24:09.633 UTC: SCCP(AND0FD4A4961401)rcvd KeepAliveAckMessage from ccm identifier 2
000894: *Mar 22 22:24:09.637 UTC: sccpapp_process_socket_events: appl_type 4, soc_fd 2, soc 2, swb_soc -1
000895: *Mar 22 22:24:09.637 UTC: sccpapp_process_socket_events: TCP_SOCKET_READ: appl_type 4, eve 4, state 6
000896: *Mar 22 22:24:09.637 UTC: sccp_get_control_message: bytes_to_read 8, bytes_read 8, appl_total_bytes 8, appl_bytes_read 8, soc_read_mode 0, soc 2
000897: *Mar 22 22:24:09.637 UTC: sccp_get_control_message: bytes_to_read 4, bytes_read 4, appl_total_bytes 4, appl_bytes_read 4, soc_read_mode 1, soc 2
000898: *Mar 22 22:24:09.637 UTC: sccp_get_control_message: sccp cntl msg rcvd, prof_id 0, appl_type 4, msg_len 4
000899: *Mar 22 22:24:09.637 UTC: sccp_parse_control_msg: msg_ptr 65C838D8, msg_len 4, msg_id 256
000900: *Mar 22 22:24:09.637 UTC: sccp_parse_control_msg: glob_ccm->version 9
000901: *Mar 22 22:24:09.637 UTC: SCCP(AND0FD4A4961405)rcvd KeepAliveAckMessage from ccm identifier 2
000902: *Mar 22 22:24:10.161 UTC: sccp_generate_msg: msg_id 0 msg_len 4 pak_size 12
000903: *Mar 22 22:24:10.161 UTC: sccp_send_keep_alive_msg_v1: send keepalive id 0, len 4
000904: *Mar 22 22:24:10.161 UTC: SCCP(AND0FD4A496140D)send KeepAliveMessage to ccm identifier 2
000905: *Mar 22 22:24:10.161 UTC: sccp_transmit_msg: sending on socket 3
000906: *Mar 22 22:24:10.161 UTC: sccp_queue_msg_to_xmit:Enqueued sccp msg,size 12, socket 3, profile_id 0
000907: *Mar 22 22:24:10.161 UTC: sccp_generate_msg: msg_id 0 msg_len 4 pak_size 12
000908: *Mar 22 22:24:10.161 UTC: sccp_send_keep_alive_msg_v1: send keepalive id 0, len 4
000909: *Mar 22 22:24:10.161 UTC: SCCP(AND0FD4A496140E)send KeepAliveMessage to ccm identifier 2
000910: *Mar 22 22:24:10.161 UTC: sccp_transmit_msg: sending on socket 4
000911: *Mar 22 22:24:10.161 UTC: sccp_queue_msg_to_xmit:Enqueued sccp msg,size 12, socket 4, profile_id 0
000912: *Mar 22 22:24:10.165 UTC: sccpapp_process_send_sccpmsg_q: Send sccp msg from sccp_msg_send_q, soc 3,  pak size 12
000913: *Mar 22 22:24:10.165 UTC: sccp_send_msg_nonblocking: Sccp message sent socket 3, profile_id 0, sent bytes 12, total pak_size 12, bytes_to_send 12
000914: *Mar 22 22:24:10.165 UTC: sccpapp_process_send_sccpmsg_q: Send sccp msg from sccp_msg_send_q, soc 4,  pak size 12
000915: *Mar 22 22:24:10.165 UTC: sccp_send_msg_nonblocking: Sccp message sent socket 4, profile_id 0, sent bytes 12, total pak_size 12, bytes_to_send 12
000916: *Mar 22 22:24:10.217 UTC: sccpapp_process_socket_events: appl_type 4, soc_fd 3, soc 3, swb_soc -1
000917: *Mar 22 22:24:10.217 UTC: sccpapp_process_socket_events: TCP_SOCKET_READ: appl_type 4, eve 4, state 6
000918: *Mar 22 22:24:10.217 UTC: sccp_get_control_message: bytes_to_read 8, bytes_read 8, appl_total_bytes 8, appl_bytes_read 8, soc_read_mode 0, soc 3
000919: *Mar 22 22:24:10.217 UTC: sccp_get_control_message: bytes_to_read 4, bytes_read 4, appl_total_bytes 4, appl_bytes_read 4, soc_read_mode 1, soc 3
000920: *Mar 22 22:24:10.217 UTC: sccp_get_control_message: sccp cntl msg rcvd, prof_id 0, appl_type 4, msg_len 4
000921: *Mar 22 22:24:10.217 UTC: sccp_parse_control_msg: msg_ptr 65D8F8E0, msg_len 4, msg_id 256
000922: *Mar 22 22:24:10.217 UTC: sccp_parse_control_msg: glob_ccm->version 9
000923: *Mar 22 22:24:10.217 UTC: SCCP(AND0FD4A496140D)rcvd KeepAliveAckMessage from ccm identifier 2
000924: *Mar 22 22:24:10.221 UTC: sccpapp_process_socket_events: appl_type 4, soc_fd 4, soc 4, swb_soc -1
000925: *Mar 22 22:24:10.221 UTC: sccpapp_process_socket_events: TCP_SOCKET_READ: appl_type 4, eve 4, state 6
000926: *Mar 22 22:24:10.221 UTC: sccp_get_control_message: bytes_to_read 8, bytes_read 8, appl_total_bytes 8, appl_bytes_read 8, soc_read_mode 0, soc 4
000927: *Mar 22 22:24:10.221 UTC: sccp_get_control_message: bytes_to_read 4, bytes_read 4, appl_total_bytes 4, appl_bytes_read 4, soc_read_mode 1, soc 4
000928: *Mar 22 22:24:10.221 UTC: sccp_get_control_message: sccp cntl msg rcvd, prof_id 0, appl_type 4, msg_len 4
000929: *Mar 22 22:24:10.221 UTC: sccp_parse_control_msg: msg_ptr 65C740E4, msg_len 4, msg_id 256
000930: *Mar 22 22:24:10.221 UTC: sccp_parse_control_msg: glob_ccm->version 9
000931: *Mar 22 22:24:10.221 UTC: SCCP(AND0FD4A496140E)rcvd KeepAliveAckMessage from ccm identifier 2
000932: *Mar 22 22:24:14.333 UTC: sccpapp_process_socket_events: appl_type 4, soc_fd 5, soc 5, swb_soc -1
000933: *Mar 22 22:24:14.333 UTC: sccpapp_process_socket_events: TCP_SOCKET_READ: appl_type 4, eve 4, state 6
000934: *Mar 22 22:24:14.333 UTC: sccp_get_control_message: bytes_to_read 8, bytes_read 8, appl_total_bytes 8, appl_bytes_read 8, soc_read_mode 0, soc 5
000935: *Mar 22 22:24:14.333 UTC: sccp_get_control_message: bytes_to_read 20, bytes_read 20, appl_total_bytes 20, appl_bytes_read 20, soc_read_mode 1, soc 5
000936: *Mar 22 22:24:14.333 UTC: sccp_get_control_message: sccp cntl msg rcvd, prof_id 0, appl_type 4, msg_len 20
000937: *Mar 22 22:24:14.333 UTC: sccp_parse_control_msg: msg_ptr 63DC8AA0, msg_len 20, msg_id 262
000938: *Mar 22 22:24:14.333 UTC: sccp_parse_control_msg: glob_ccm->version 9
000939: *Mar 22 22:24:14.333 UTC: SCCP(AND0FD4A4961406)rcvd CloseReceiveChannel
000940: *Mar 22 22:24:14.333 UTC: CloseReceviceChannel msg rcvd in hex -
6 1 0 0 71 F1 AC E 57 74 A E 71 F1 AC E 0 0 0 0
000941: *Mar 22 22:24:14.337 UTC: CloseReceiveChannelMsg Info:
conference_id = 246215025, pass_through_party_id = 235566167, call_ref = 246215025, port_handling = 0
000942: *Mar 22 22:24:14.337 UTC: sccpapp_process_socket_events: appl_type 4, soc_fd 5, soc 5, swb_soc -1
000943: *Mar 22 22:24:14.337 UTC: sccpapp_process_socket_events: TCP_SOCKET_READ: appl_type 4, eve 4, state 6
000944: *Mar 22 22:24:14.337 UTC: sccp_get_control_message: bytes_to_read 8, bytes_read 8, appl_total_bytes 8, appl_bytes_read 8, soc_read_mode 0, soc 5
000945: *Mar 22 22:24:14.337 UTC: sccp_get_control_message: bytes_to_read 20, bytes_read 20, appl_total_bytes 20, appl_bytes_read 20, soc_read_mode 1, soc 5
000946: *Mar 22 22:24:14.337 UTC: sccp_get_control_message: sccp cntl msg rcvd, prof_id 0, appl_type 4, msg_len 20
000947: *Mar 22 22:24:14.341 UTC: sccp_parse_control_msg: msg_ptr 63DC8AA0, msg_len 20, msg_id 139
000948: *Mar 22 22:24:14.341 UTC: sccp_parse_control_msg: glob_ccm->version 9
000949: *Mar 22 22:24:14.341 UTC: SCCP(AND0FD4A4961406)rcvd StopMediaTransmission
000950: *Mar 22 22:24:14.341 UTC: StopMediaTrans msg rcvd in hex -
8B 0 0 0 71 F1 AC E 57 74 A E 71 F1 AC E 0 0 0 0
000951: *Mar 22 22:24:14.341 UTC: StopMediaTransmissionMsg Info:
000952: *Mar 22 22:24:14.345 UTC: sccpapp_process_socket_events: appl_type 4, soc_fd 5, soc 5, swb_soc -1
000953: *Mar 22 22:24:14.345 UTC: sccpapp_process_socket_events: TCP_SOCKET_READ: appl_type 4, eve 4, state 6
000954: *Mar 22 22:24:14.345 UTC: sccp_get_control_message: bytes_to_read 8, bytes_read 8, appl_total_bytes 8, appl_bytes_read 8, soc_read_mode 0, soc 5
000955: *Mar 22 22:24:14.345 UTC: sccp_get_control_message: bytes_to_read 20, bytes_read 20, appl_total_bytes 20, appl_bytes_read 20, soc_read_mode 1, soc 5
000956: *Mar 22 22:24:14.345 UTC: sccp_get_control_message: sccp cntl msg rcvd, prof_id 0, appl_type 4, msg_len 20
000957: *Mar 22 22:24:14.349 UTC: sccp_parse_control_msg: msg_ptr 63DC8AA0, msg_len 20, msg_id 130
000958: *Mar 22 22:24:14.349 UTC: sccp_parse_control_msg: glob_ccm->version 9
000959: *Mar 22 22:24:14.349 UTC: SCCP(AND0FD4A4961406)rcvd StartToneMessage
000960: *Mar 22 22:24:14.349 UTC: StartToneMsg Info:
    tone: 37, direction: 0, line: 1, call_ref: 246215025
000961: *Mar 22 22:24:14.353 UTC: sccpapp_process_socket_events: appl_type 4, soc_fd 5, soc 5, swb_soc -1
000962: *Mar 22 22:24:14.353 UTC: sccpapp_process_socket_events: TCP_SOCKET_READ: appl_type 4, eve 4, state 6
000963: *Mar 22 22:24:14.353 UTC: sccp_get_control_message: bytes_to_read 8, bytes_read 8, appl_total_bytes 8, appl_bytes_read 8, soc_read_mode 0, soc 5
000964: *Mar 22 22:24:14.353 UTC: sccp_get_control_message: bytes_to_read 88, bytes_read 88, appl_total_bytes 88, appl_bytes_read 88, soc_read_mode 1, soc 5
000965: *Mar 22 22:24:14.353 UTC: sccp_get_control_message: sccp cntl msg rcvd, prof_id 0, appl_type 4, msg_len 88
000966: *Mar 22 22:24:14.353 UTC: sccp_parse_control_msg: msg_ptr 63DC8AA0, msg_len 88, msg_id 330
000967: *Mar 22 22:24:14.353 UTC: sccp_parse_control_msg: glob_ccm->version 9
000968: *Mar 22 22:24:14.353 UTC: SCCP(AND0FD4A4961406)rcvd CallInfoV2Message
000969: *Mar 22 22:24:14.353 UTC: CallInfoV2Msg Info:
    called party name:
    called party:
KIETDAG001(config-voiceport)#    line instance:              1
    call type:                  2
    orig called pty:
    cgpn voice mailbox:
    cdpn voice mailbox:
    call instance:              1
    call security status:       0
KIETDAG001(config-voiceport)#^Z
KIETDAG001#
KIETDAG001#
KIETDAG001#
KIETDAG001#
KIETDAG001#u
000970: *Mar 22 22:24:23.909 UTC: %SYS-5-CONFIG_I: Configured from console by obsadmin on vty0 (10.132.192.49)
KIETDAG001#u all
All possible debugging has been turned off
KIETDAG001#
KIETDAG001#
KIETDAG001#
KIETDAG001#
KIETDAG001#
KIETDAG001#
moataz_mamdouh Wed, 03/05/2014 - 10:44
003510: *Mar 22 22:31:25.721 UTC: sccp_generate_msg: msg_id 0 msg_len 4 pak_size 12
003511: *Mar 22 22:31:25.721 UTC: sccp_send_keep_alive_msg_v1: send keepalive id 0, len 4
003512: *Mar 22 22:31:25.721 UTC: sccp_transmit_msg: sending on socket 0
003513: *Mar 22 22:31:25.721 UTC: sccp_queue_msg_to_xmit:Enqueued sccp msg,size 12, socket 0, profile_id 0
003514: *Mar 22 22:31:25.721 UTC: sccpapp_process_send_sccpmsg_q: Send sccp msg from sccp_msg_send_q, soc 0,  pak size 12
003515: *Mar 22 22:31:25.721 UTC: sccp_send_msg_nonblocking: Sccp message sent socket 0, profile_id 0, sent bytes 12, total pak_size 12, bytes_to_send 12
003516: *Mar 22 22:31:25.749 UTC: sccp_generate_msg: msg_id 0 msg_len 4 pak_size 12
003517: *Mar 22 22:31:25.749 UTC: sccp_send_keep_alive_msg_v1: send keepalive id 0, len 4
003518: *Mar 22 22:31:25.749 UTC: sccp_transmit_msg: sending on socket 1
003519: *Mar 22 22:31:25.749 UTC: sccp_queue_msg_to_xmit:Enqueued sccp msg,size 12, socket 1, profile_id 0
003520: *Mar 22 22:31:25.749 UTC: sccpapp_process_send_sccpmsg_q: Send sccp msg from sccp_msg_send_q, soc 1,  pak size 12
003521: *Mar 22 22:31:25.749 UTC: sccp_send_msg_nonblocking: Sccp message sent socket 1, profile_id 0, sent bytes 12, total pak_size 12, bytes_to_send 12
003522: *Mar 22 22:31:25.761 UTC: sccp_generate_msg: msg_id 0 msg_len 4 pak_size 12
003523: *Mar 22 22:31:25.761 UTC: sccp_send_keep_alive_msg_v1: send keepalive id 0, len 4
003524: *Mar 22 22:31:25.761 UTC: sccp_transmit_msg: sending on socket 2
003525: *Mar 22 22:31:25.761 UTC: sccp_queue_msg_to_xmit:Enqueued sccp msg,size 12, socket 2, profile_id 0
003526: *Mar 22 22:31:25.761 UTC: sccpapp_process_send_sccpmsg_q: Send sccp msg from sccp_msg_send_q, soc 2,  pak size 12
003527: *Mar 22 22:31:25.761 UTC: sccp_send_msg_nonblocking: Sccp message sent socket 2, profile_id 0, sent bytes 12, total pak_size 12, bytes_to_send 12
003528: *Mar 22 22:31:25.773 UTC: sccpapp_process_socket_events: appl_type 4, soc_fd 0, soc 0, swb_soc -1
003529: *Mar 22 22:31:25.773 UTC: sccpapp_process_socket_events: TCP_SOCKET_READ: appl_type 4, eve 4, state 6
003530: *Mar 22 22:31:25.773 UTC: sccp_get_control_message: bytes_to_read 8, bytes_read 8, appl_total_bytes 8, appl_bytes_read 8, soc_read_mode 0, soc 0
003531: *Mar 22 22:31:25.773 UTC: sccp_get_control_message: bytes_to_read 4, bytes_read 4, appl_total_bytes 4, appl_bytes_read 4, soc_read_mode 1, soc 0
003532: *Mar 22 22:31:25.773 UTC: sccp_get_control_message: sccp cntl msg rcvd, prof_id 0, appl_type 4, msg_len 4
003533: *Mar 22 22:31:25.777 UTC: sccp_parse_control_msg: msg_ptr 65DA62E4, msg_len 4, msg_id 256
003534: *Mar 22 22:31:25.777 UTC: sccp_parse_control_msg: glob_ccm->version 9
003535: *Mar 22 22:31:25.801 UTC: sccpapp_process_socket_events: appl_type 4, soc_fd 1, soc 1, swb_soc -1
003536: *Mar 22 22:31:25.801 UTC: sccpapp_process_socket_events: TCP_SOCKET_READ: appl_type 4, eve 4, state 6
003537: *Mar 22 22:31:25.801 UTC: sccp_get_control_message: bytes_to_read 8, bytes_read 8, appl_total_bytes 8, appl_bytes_read 8, soc_read_mode 0, soc 1
003538: *Mar 22 22:31:25.801 UTC: sccp_get_control_message: bytes_to_read 4, bytes_read 4, appl_total_bytes 4, appl_bytes_read 4, soc_read_mode 1, soc 1
003539: *Mar 22 22:31:25.801 UTC: sccp_get_control_message: sccp cntl msg rcvd, prof_id 0, appl_type 4, msg_len 4
003540: *Mar 22 22:31:25.801 UTC: sccp_parse_control_msg: msg_ptr 65C731D0, msg_len 4, msg_id 256
003541: *Mar 22 22:31:25.801 UTC: sccp_parse_control_msg: glob_ccm->version 9
003542: *Mar 22 22:31:25.813 UTC: sccp_generate_msg: msg_id 0 msg_len 4 pak_size 12
003543: *Mar 22 22:31:25.813 UTC: sccp_send_keep_alive_msg_v1: send keepalive id 0, len 4
003544: *Mar 22 22:31:25.813 UTC: sccp_transmit_msg: sending on socket 4
003545: *Mar 22 22:31:25.813 UTC: sccp_queue_msg_to_xmit:Enqueued sccp msg,size 12, socket 4, profile_id 0
003546: *Mar 22 22:31:25.813 UTC: sccpapp_process_socket_events: appl_type 4, soc_fd 2, soc 2, swb_soc -1
003547: *Mar 22 22:31:25.813 UTC: sccpapp_process_socket_events: TCP_SOCKET_READ: appl_type 4, eve 4, state 6
003548: *Mar 22 22:31:25.813 UTC: sccp_get_control_message: bytes_to_read 8, bytes_read 8, appl_total_bytes 8, appl_bytes_read 8, soc_read_mode 0, soc 2
003549: *Mar 22 22:31:25.813 UTC: sccp_get_control_message: bytes_to_read 4, bytes_read 4, appl_total_bytes 4, appl_bytes_read 4, soc_read_mode 1, soc 2
003550: *Mar 22 22:31:25.813 UTC: sccp_get_control_message: sccp cntl msg rcvd, prof_id 0, appl_type 4, msg_len 4
003551: *Mar 22 22:31:25.813 UTC: sccp_parse_control_msg: msg_ptr 65C916C0, msg_len 4, msg_id 256
003552: *Mar 22 22:31:25.813 UTC: sccp_parse_control_msg: glob_ccm->version 9
003553: *Mar 22 22:31:25.817 UTC: sccpapp_process_send_sccpmsg_q: Send sccp msg from sccp_msg_send_q, soc 4,  pak size 12
003554: *Mar 22 22:31:25.817 UTC: sccp_send_msg_nonblocking: Sccp message sent socket 4, profile_id 0, sent bytes 12, total pak_size 12, bytes_to_send 12
003555: *Mar 22 22:31:25.833 UTC: sccp_generate_msg: msg_id 0 msg_len 4 pak_size 12
003556: *Mar 22 22:31:25.833 UTC: sccp_send_keep_alive_msg_v1: send keepalive id 0, len 4
003557: *Mar 22 22:31:25.833 UTC: sccp_transmit_msg: sending on socket 5
003558: *Mar 22 22:31:25.833 UTC: sccp_queue_msg_to_xmit:Enqueued sccp msg,size 12, socket 5, profile_id 0
003559: *Mar 22 22:31:25.833 UTC: sccpapp_process_send_sccpmsg_q: Send sccp msg from sccp_msg_send_q, soc 5,  pak size 12
003560: *Mar 22 22:31:25.833 UTC: sccp_send_msg_nonblocking: Sccp message sent socket 5, profile_id 0, sent bytes 12, total pak_size 12, bytes_to_send 12
003561: *Mar 22 22:31:25.869 UTC: sccpapp_process_socket_events: appl_type 4, soc_fd 4, soc 4, swb_soc -1
003562: *Mar 22 22:31:25.869 UTC: sccpapp_process_socket_events: TCP_SOCKET_READ: appl_type 4, eve 4, state 6
003563: *Mar 22 22:31:25.869 UTC: sccp_get_control_message: bytes_to_read 8, bytes_read 8, appl_total_bytes 8, appl_bytes_read 8, soc_read_mode 0, soc 4
003564: *Mar 22 22:31:25.869 UTC: sccp_get_control_message: bytes_to_read 4, bytes_read 4, appl_total_bytes 4, appl_bytes_read 4, soc_read_mode 1, soc 4
003565: *Mar 22 22:31:25.869 UTC: sccp_get_control_message: sccp cntl msg rcvd, prof_id 0, appl_type 4, msg_len 4
003566: *Mar 22 22:31:25.869 UTC: sccp_parse_control_msg: msg_ptr 65DB7918, msg_len 4, msg_id 256
003567: *Mar 22 22:31:25.869 UTC: sccp_parse_control_msg: glob_ccm->version 9
003568: *Mar 22 22:31:25.885 UTC: sccpapp_process_socket_events: appl_type 4, soc_fd 5, soc 5, swb_soc -1
003569: *Mar 22 22:31:25.885 UTC: sccpapp_process_socket_events: TCP_SOCKET_READ: appl_type 4, eve 4, state 6
003570: *Mar 22 22:31:25.885 UTC: sccp_get_control_message: bytes_to_read 8, bytes_read 8, appl_total_bytes 8, appl_bytes_read 8, soc_read_mode 0, soc 5
003571: *Mar 22 22:31:25.885 UTC: sccp_get_control_message: bytes_to_read 4, bytes_read 4, appl_total_bytes 4, appl_bytes_read 4, soc_read_mode 1, soc 5
003572: *Mar 22 22:31:25.889 UTC: sccp_get_control_message: sccp cntl msg rcvd, prof_id 0, appl_type 4, msg_len 4
003573: *Mar 22 22:31:25.889 UTC: sccp_parse_control_msg: msg_ptr 65DB8954, msg_len 4, msg_id 256
003574: *Mar 22 22:31:25.889 UTC: sccp_parse_control_msg: glob_ccm->version 9
moataz_mamdouh Wed, 03/05/2014 - 10:47
here is the error
SCCP(AND0FD4A4961407)rcvd RegisterRejectMessage
003676: *Mar 22 22:32:04.917 UTC: sccp_appl_service_stop_timer: Stop 65E08968 timer
003677: *Mar 22 22:32:04.917 UTC: sccp_parse_control_msg_v1: rcvd register rej, reason: Security Error
moataz_mamdouh Wed, 03/05/2014 - 11:09
this is unrelated I got this error (AND0FD4A4961407)rcvd RegisterRejectMessage rcvd RegisterRejectMessage) because port 2/7 is not added on the call manager
I have other ports added on the call manager like AND0FD4A4961402 which 2/2 but when I shut and no shut this port , I can see its status unregistered on the call manager but at the same time in the debug i could not see any signalling or events are generated by this ports
looks like the port is not responding or something
