verify PRI working
Sep 3rd, 2008
Installing a new PRI at new location. Can I take a 2611 non voice sw, with a plain wic (not vwic), and use it to verify whether all 24 channels are up or not?
vmoopeung Tue, 09/09/2008 - 08:07
The “show ISDN status” command ensures that the router is properly communicating with the ISDN switch. In the output, verify that Layer 1 Status is ACTIVE, and that the Layer 2 Status state = MULTIPLE_FRAME_ESTABLISHED appears. This command also displays the number of active calls.
balitewiczp Tue, 09/09/2008 - 08:19
thanks for the response. the question is where I could take a straight data WIC card on a router with non voice ios, and use that just to verify the PRI comes up
Kenneth Mohammed Tue, 09/09/2008 - 11:16
You would need at least a network module that would recognize ISDN PRI, like an NM-2CT1-CSU=, or NM-2CE1T1-PRI.
If helpful, please rate.
