CEM 5.0 issue
Sep 4th, 2008
We are using CEM 5.0 with IPCC 7.1. We need to edit the system generated auto reply message. When a customer sends a mail to customerservice the CEM generate a reply message including the following two line:
"Please include the following line in all replies.
Tracking number: *******_****** "
We need to remove the first line.
Kindly guide us to do the same.
asif.akram Fri, 09/05/2008 - 10:11
I checked the rserver.cfg file but it doesn't contain those lines.The doc which you provide also tells the same.Kindly help me wht to do nxt.
khambetea Mon, 09/08/2008 - 03:46
Check instance_mailtrack.properties under drive letter:\\Cisco\E-mail Manager\bin
For mailserverreplymailcmdhdlr.PKTRACKLINE=Please include the following line in all replies.\r\n
I would keep a copy of the file before changing it and plan this change in a maintenance window.
