LAN-to-LAN VPN
Answered Question
Sep 4th, 2008
I currently have a PIX setup at SiteA and a 1720 router at SiteB. There is a LAN-to-LAN tunnel between the 2 sites. If I was to setup a second tunnel at SiteB terminating on the 1720 router, will it be possible to configure the tunnels so SiteA also has access to the customer VPN tunnel?
I would also want to have VPN tunnels that terminate at the PIX (SiteA) to also be accessible from SiteB.
Would it just be a case of configuring the crypto ACL's for the traffic?
Correct Answer by Marwan ALshawi about 8 years 10 months ago
have a look at the following link will be very usefull
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a00807f9a89.shtml
good luck
if helpful Rate
Overall Rating: 5 (2 ratings)
alraycisco Thu, 09/04/2008 - 02:31
I think that helps. From my understanding of it, for the customer VPN tunnels that terminate on the 1720 and that need to be accessed from behind the PIX, I should only need to modify the crypto map acl's and the NAT0 acl's. The same interface traffic issue doesn't apply in this case. Is this correct?
grant.maynard Thu, 09/04/2008 - 04:42
  • Silver, 250 points or more
correct, the 1720 won't have a problem with same interface traffic.
