cisco 3560G rebooring
Sep 4th, 2008
i have 3560G switch with ios c3560-ipbase-mz.122-35.SE5.bin.
it is getting rebooting.find below output while rebooting automatically.
Initializing flashfs...
flashfs[1]: 508 files, 8 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 32514048
flashfs[1]: Bytes used: 16192512
flashfs[1]: Bytes available: 16321536
flashfs[1]: flashfs fsck took 1 seconds.
flashfs[1]: Initialization complete....done Initializing flashfs.
front_end/ (directory)
extracting front_end/fe_type_1 (34696 bytes)
extracting front_end/front_end_ucode_info (43 bytes)
extracting ucode_info (76 bytes)
POST: CPU MIC register Tests : Begin
POST: CPU MIC register Tests : End, Status Passed
POST: PortASIC Memory Tests : BeginAddress Bus test failed at address 40400000 wrote 8040201 read FFFFFFFF
POST: PortASIC Memory Tests : End, Status Failed
POST: CPU MIC interface Loopback Tests : Begin
POST: CPU MIC interface Loopback Tests : End, Status Passed
POST: PortASIC RingLoopback Tests : Begin
POST: Failed Packet Receive asic 0 queue 0
POST: PortASIC RingLoopback Tests : End, Status Failed
POST: port-asic ring loopback test failed
driver class subsystem initialization failed
00:00:12: %SYS-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
00:00:12: %SYS-2-ASSERTION_FAILED: Assertion failed: "reg_used_xdr_portid_to_lc_logical_slot()"
-Process= "Init", ipl= 0, pid= 3
-Traceback= B4C12C 26287C 262AFC F3B274 F3B314 BBB978 BBBBA4 975510 96CAE4
%Software-forced reload
00:00:12 UTC Mon Mar 1 1993: Unexpected exception to CPUvector 2000, PC = 973754
-Traceback= 973754 97367C 26287C 262AFC F3B274 F3B314 BBB978 BBBBA4 975510 96CAE4
Writing crashinfo to flash:/crashinfo_ext/crashinfo_ext_29
=== Flushing messages (00:00:15 UTC Mon Mar 1 1993) ===
Buffered messages:
Queued messages:
00:00:64424509444: %SYS-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
00:00:12: %SYS-3-LOGGER_FLUSHED: System was paused for 00:00:00 to ensure console debugging output.
Cisco IOS Software, C3560 Software (C3560-IPBASE-M), Version 12.2(35)SE5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Thu 19-Jul-07 18:15 by nachen
Debug Exception (Could be NULL pointer dereference) Exception (0x2000)!
SRR0 = 0x0062DEB8 SRR1 = 0x00029230 CPU Register Context:
Vector = 0x00002000 PC = 0x00973754 MSR = 0x00029230 CR = 0x22000024
LR = 0x0097367C CTR = 0x00000000 XER = 0x4000005B
Frame 04: SP = 0x01B78558 PC = 0x00F3B274
Frame 05: SP = 0x01B78570 PC = 0x00F3B314
Frame 06: SP = 0x01B78590 PC = 0x00BBB978
Frame 07: SP = 0x01B78688 PC = 0x00BBBBA4
Frame 08: SP = 0x01B78690 PC = 0x00975510
Frame 09: SP = 0x00000000 PC = 0x0096CAE4
Switch uptime is 18 seconds
cisco WS-C3560G-48PS (PowerPC405) processor (revision F0) with 122880K/8184K bytes of memory.
Processor board ID FOC1148Y1CP
Base ethernet MAC Address: 00:1e:bd:00:64:00
Xmodem file system is available.
The password-recovery mechanism is enabled.
Initializing Flash...
flashfs[0]: 510 files, 8 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 32514048
flashfs[0]: Bytes used: 16449536
flashfs[0]: Bytes available: 16064512
flashfs[0]: flashfs fsck took 8 seconds.
...done Initializing Flash.
Boot Sector Filesystem (bs) installed, fsid: 3
done.
Loading "flash:c3560-ipbase-mz.122-35.SE5/c3560-ipbase-mz.122-35.SE5.bin"...@@@@@@
File "flash:c3560-ipbase-mz.122-35.SE5/c3560-ipbase-mz.122-35.SE5.bin" uncompressed and installed, entry point: 0x3000
executing...
Pls help me on this.
regards,
subash
arupbiet2006 Thu, 09/04/2008 - 01:38
hi subash ur router flash is going to damage.change the router flash.
satish_zanjurne Thu, 09/04/2008 - 01:46
  • Silver, 250 points or more
Hi Subhash,
The output
""POST: PortASIC Memory Tests : BeginAddress Bus test failed at address 40400000 wrote 8040201 read FFFFFFFF
show that " PortASIC Memory Tests " "PortASIC RingLoopback Tests "
which is part of GOLD POST is failed.
This is hardware issue & you need to change the hardware, get it RMA/replaced done.
HTH..rate if helpful..
glen.grant Thu, 09/04/2008 - 03:33
  • Purple, 4500 points or more
Its failing a "POST" test you will to get it RMA'd by cisco.
arupbiet2006 Thu, 09/04/2008 - 01:48
