satish_zanjurne Thu, 09/04/2008 - 01:55
  • Silver, 250 points or more
can you attach the configuration ??
Hope you have configured essential the "ip nat inside" & "ip nat outside" under the correct interface ??
Also you must have configured the NAT pool if you are not doing overload ??
HTH..rate if helpful..
smohanasundaram Fri, 09/05/2008 - 03:08
Please go through the following configuration example.
Fastethernet 0/0
ip address 192.168.0.1 255.255.255.0
Fastethernet 0/1
ip address 10.0.0.1 255.255.225.0
ip nat inside
Serial 0/0/0
ip address 125.25.23.12 255.255.255.254
encapsulation ppp
ip nat ouside
ip nat inside source list 101 interface serial 0/0/0 overload
access-list 101 permit ip 10.0.0.0 0.255.255.255 any
S.Mohana sundaram
