CCM 4.2 logs
Sep 4th, 2008
This is a simple question.
Where in a CCM 4.2 can I find a log showing the event of a CCM cluster failover? I mean, when all the phones start registering with the second CCM server in their list.
Thanks for your help
Overall Rating: 4 (1 ratings)
tim.giles Thu, 09/04/2008 - 03:24
You should be able to find this information in the trace logs which can be found in the following directory on the CallManager:
c:\program files\cisco\trace\CCM
These contain A LOT of info depending on what traces you have enabled but they should also show you when phones re-registed as well.
Some info on unregisted devices will also be available in the event logs on either server.
Please rate useful posts....
