"Location" Parameter Calculator
Answered Question
Sep 4th, 2008
Hi there,
Is there any calculator available to determine the Audio Bandwidth for a location?
Thanks.
Correct Answer by Marwan ALshawi about 8 years 6 months ago
u mean u have two locations that mean u have created two regions right?
what codec do u use between reagions?
if u use g711 then
512/80 about 6 calls
if g729 about 21 call
but if u use g711 bwith the site and g721 between locations in this case u will need a trnascoder!
just put 512 in the audio bandwidth
good luck
if helpful Rate
Overall Rating: 5 (1 ratings)
Marwan ALshawi Thu, 09/04/2008 - 02:28
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
this is cisco bandwidth calculator for voice need registered useres
https://tools.cisco.com/Support/VBC/authc/forms/CDClogin.fcc?TYPE=33619969&REALMOID=06-000e3fb4-2d43-142b-95c5-83846dc90000&GUID=0&SMAUTHREASON=0&METHOD=GET&SMAGENTNAME=$SM$GDuJAbSsi7kExzQDRfPKUItt%2bPcjKOjTGlbtk%2fRp7BdNYLiP9lyOBjXBU5PAxIXD&TARGET=http%3A%2F%2Ftools.cisco.com%2FSupport%2FVBC%2Fjsp%2FCodec_Calc1.jsp
keep in mind the folowoing facts
each g711 call with location CAC in CCM need 80k while on IOS GK needs 128k
each g729 call with locations CAC in CCM needs 24k while with IOS GK needs 16k
good luck
if helpful Rate
ysanadiga01 Thu, 09/04/2008 - 02:33
Hi marwanshawi,
Thanks for your answer. I hope you can help me with this. If I have a 512 line, what should I choose in Audio Bandwidth field?
Correct Answer
Marwan ALshawi Thu, 09/04/2008 - 02:35
if u use g711 then
good luck
if helpful Rate
