How to change "sdm prefer" to DEFAULT on Catalyst 3550
Sep 4th, 2008
I need to change "sdm prefer" on my catalyst 3550 to default ,but in command selection I don't have "default" value:
3550(config)#sdm prefer ?
access multicast and qos/acl bias, drop unicast
extended-match Using extended match for unicast routing
routing unicast bias, drop qos/acl
vlan vlan bias, drop routing
garytayl Thu, 09/04/2008 - 04:50
That is correct there is no default option, the way that I know is by using global configuration command: no sdm prefer
That will get the switch to go back to its default value.
Hope it helps...
