Remote access VPN
I tried using remote vpn on my ASA.Connecting thorugh the client doesn't authenticate.
Would like to know Do I need to use any Nat0 access list for remote vpn as well.Internal range is something and using virtual ips like is failing on IKE phase 1 itself.
Any point Do I need to take care while setting up the same?
Overall Rating: 5 (1 ratings)
JORGE RODRIGUEZ Thu, 09/04/2008 - 04:06
What method of user authentication are you using local or radius, have a look here with example of local user auth, you will need nat 0 access list to allow traffic between vpn pool to inside lan net.
the nonat acl would look somthing as:
access-list nonat extended permit ip
nat (inside) 0 access-list nonat
