LMS 3.x and VMWare support
Sep 4th, 2008
We have to install LMS 3.x on a VMware server. Is the following server spec supported:
Virtual OS: Windows 2003 Enterprise SP2 english
Virtual machine OS: VMWare Server 1.06
Server OS: Redhat 5.02
If yes, is there some specific Hardware requirements ?
Joe Clarke Thu, 09/04/2008 - 04:09
Only LMS 3.0.1 and higher is supported on VMWare. Only VMWare ESX 3.0.1 and 3.5 are supported. Therefore, your configuration would not be supported. The hardware and VM requirements depend on the number of devices you will be managing. See http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/3.1/install/guide/prereq.html#wp1074572 for the LMS 3.1 requirements.
