Console Login
Sep 4th, 2008
HI,
I took console for 1760Router after booting the router.it's asking system configuration dialog then i gaiven nobut it's not accepting that even yes also
what could be the probelm and what are the points i want to check
Overall Rating: 5 (1 ratings)
guruprasadr Thu, 09/04/2008 - 23:01
HI SasiKumar, [Pls RATE If HELPS]
As discussed over phone,
You were in Prompt:
Router>
your next steps are as below:
Router> enable
Router#
Router# show startup-config
Router# copy startup-config running-config
Router# configure terminal
Router(config)# enable secret
Router# config-register 0x2102
Router(config)# Ctrl-Z
Router# copy running-config startup-config
Reboot the router, and enter the enable secret password.
PLS RATE if HELPS
Best Regards,
Guru Prasad R
