Security conversion Tool (SCT)
Sep 4th, 2008
Does someone knows how to format a "ifconfig -a" output from checkpoint secureplatform and make it compatible with the format of file for routes and interfaces information that the Cisco conversion tool accepts.
The documentation says that nokia ipso and secureplatform "ifconfig -a" output are accepted but it seems that only the nokia ipso output command is recognized.
The error message that I got from the tool is :
internal error: Error...invalid format in the input file <path of the file> line = eth0
Thanks for any help
cisco24x7 Fri, 09/05/2008 - 11:15
  • Silver, 250 points or more
What are you trying to achieve here? Convert
a Checkpoint Security policy to ASA security
policy using SCT?
If you have a complicate Checkpoint security
policy, you can forget about using the SCT.
It just does NOT work and give you more
headache than it worth.
Anand Kanani Wed, 05/21/2014 - 01:35
  • Cisco Employee,
(for the benefit of the new readers)
Here is the new self-service tool that Cisco has released to convert to any vendor firewalls to Cisco ASA.
Currently it supports Juniper ScreenOS and CheckPoint to Cisco ASA conversion.
Link to the original post:
https://supportforums.cisco.com/community/netpro/security/firewall/blog/2013/12/19/conversion-tool--checkpoint-fw-to-cisco-asa
Link to the tool itself:
https://fwmig.cisco.com
