Tommer Catlin Thu, 09/04/2008 - 08:20
  • Green, 3000 points or more
I typically make a call handler for new deployments and assign it to the default. It will say something like "hello, you have reached the voicemail system for company xyz. To check your messages, please press the star key followed by your 6 digit mailbox id. Remember, your 6 digit ID is your site code and 4 digit extensions."
Once they get it, we will edit the message down, or leave it depending on the customer.
testeven Thu, 09/04/2008 - 11:31
  • Cisco Employee,
Hi!
You can change the wav files but be aware this is NOT TAC supported.
I believe the prompt you are looking for is:
C:\CommServer\Localize\Prompts\ENU\G711\AvSubSignIn\AvSubSignInENU001.wav
In that folder there's a prompt.ini text file that includes what prompt is on each file.
Note: Save the .wav files in a different folder so you do not lose them when
you make changes.
Hope this helps!
jeff.singh_2 Thu, 09/04/2008 - 12:56
Tere, without searching the ini files how do you know which file is playing the prompt, port status monitor shows me the script i.e.subauthenticate.cd!getidfromuser. You are right the file is avsubsigninenu001.wav, I just want to know which tool will tell you the wav file being used?
Jaime Valencia Thu, 09/04/2008 - 13:40
  • Cisco Employee,
  • Hall of Fame,
    2011
no tool can tell you that, as you mentioned the port status monitor only shows the script and the script is the one that invokes the audio file. you would need to read a unity trace to find that out if you don't want to read the ini file
java
if this helps, please rate
Tommer Catlin Thu, 09/04/2008 - 14:03
Just record a new WAV file and copy over the avsubsigninenu001.wav. Keeping the same will not break the SQL links then.
testeven Thu, 09/04/2008 - 15:56
  • Cisco Employee,
Exactly, just record a new wav with the same name and the wav file will be invoked by the script.
Hope this helps!
jeff.singh_2 Fri, 09/05/2008 - 03:53
Tim, where are you placing the new CH - I placed it in call routing direct calls and this did not work.
