09-04-2008 05:43 AM - edited 03-15-2019 01:02 PM
Does anyone have one URL that has all the logo sizes? I am looking to resize images for the following phone types - 7911, 7912, 7940 & 7960
I am trying to establish the TN size for the 7911 & 7912 as well as the logo size.
James
09-04-2008 06:01 AM
Hi James,
I came across this great post from Martin recently. He has done a real nice job on this doc (I just added my 5 point vote for his hard work :)
Hope this helps!
Rob
09-04-2008 06:14 AM
Hi Rob,
Thanks for getting back ASAP.
Do you know if you can use the same file size for the 7912 as you can for the 7911?
The 7911 it says to use -
95x34x1 - Logo & TN of 23x8
The 7912 only gives you a logo size -
88x27x1 - Logo But no Thumb Nail
Any idea?
Thanks again.
James
09-05-2008 08:50 AM
I'm just about 100% sure here, but someone correct me if I'm wrong... - The 7912 requires the logo to be added to the firmware of the phone. You actually make a new firmware file using a logo tool that Cisco has, and then force that load out to your phones and the logo appears. Thusly no thumbnail is needed, becuase it is an on or off change, not just something that the user can choose.
Steve
09-07-2008 06:49 AM
Hi Steve,
Do you have any documentation on where this Cisco tool is and how to carry out this procedure?
If you have anything that would be great.
Cheers,
James
