easy vpn
Sep 4th, 2008
Dear Sir,
Please could you tell me if VTI means ip sec configuration and the difference they have ineach of them ?
ebreniz Wed, 09/10/2008 - 08:25
Virtual Tunnel Interface(VTI) you can create GRE tunnels between your locations with encapsulation mode as GRE so that you can have the communication between locations done through the tunnel...
Instead of having IPSEC tunnels you can consider these tunnels but they are just an encapsulation mechanism and doesnt provide any kinda security to your data...
If you are concerned about security to the data transfer being done between the locations better look out for IPSEC tunnels
http://www.cisco.com/en/US/docs/solutions/Enterprise/WAN_and_MAN/V3PNIPmc.html#wp337439
