WAAS 4.1.1 - Map Default
Answered Question
Sep 4th, 2008
What does **Map Default** in the classifier name column within the connection summary table mean?
Correct Answer by Zach Seils about 8 years 5 months ago
Hi Richard,
The **Map Default** designation means that the connection was classified with EPM (i.e. MS-RPC traffic). If you click on the magnifying glass to the left of the connection, the popup shows the matched application and UUID.
Zach
Overall Rating: 5 (1 ratings)
Correct Answer
Zach Seils Thu, 09/04/2008 - 10:42
Hi Richard,
Zach
