Phones Not Updating Configuration
Sep 4th, 2008
I've been working on several phones, and the phones themselves are not updating. I've restarted the TFTP service in OS Serviceability to no avail. I'm not even sure where to start. I'm running CUCM 6.1 integrated with OCS 2007.
gogasca Thu, 09/04/2008 - 07:38
  • Green, 3000 points or more
What is the status of DBreplication must be set to 2, in CUCM 6.1 IDS replication is vital for CUCM change notification.
How many servers?
What exactly is not being updated?
Darren Roback Thu, 09/04/2008 - 11:01
I used the RTMT to check the database summary, and both are reporting 2, with no changes sitting in the queue...
Darren Roback Thu, 09/04/2008 - 11:02
We have two servers in our cluster, and it's just the general changes that aren't taking affect (phone line changes, route/hunt changes, etc.). Thanks for your suggestions thus far!
gogasca Thu, 09/04/2008 - 12:28
Could you please try restarting DBMon service in all servers, then try again.
If you require RCA, I suggest you to open a TAC case.
Looks like a Change notification problem.
Darren Roback Thu, 09/04/2008 - 12:42
I restarted the service on my pub as well as sub to no avail. I have a case open with Cisco (actually opened it this morning), but we've still been unable to resolve the issue...
Kevin Long Tue, 09/28/2010 - 11:48
Hi there,
I am having a very similar issue with my CUCM 7.1.3, all of the sudden I can make changes but the devices will not update, reset, or anything.  My DB Replication status is 2 and 2 between servers.  Did you ever find a resolution to this problem with TAC?  I am waiting to hear back from them in the meantime.  I appreciate any light shed on this!
Thanks.
Kevin Long Sun, 02/13/2011 - 01:01
FYI, I rebooted my Publisher Server and all is well now.  It looks like another Engineer and
TAC were in the Server and TAC had them restart the DBMon Service to try to fix a different issue.
The service came back up but it really hosed everything up as described earlier.  Once I rebooted the
Publisher we were back to normal.
Hope this helps someone!
Joseph Martini Sun, 02/13/2011 - 04:39
  • Cisco Employee,
What's the full version of CUCM 6.1.x.yyyy-zz?  It should very much like CSCso93220, which can be verified prior to the reboot with a "show tech notify" from the command line.
