CALLMANAGER-QSIG-GF-ALCATEL-4400
Sep 4th, 2008
Hi all,
I'm having the folowing senario,
PSTN-->CISCO-GW-2821---->CALLMA-(QSIG-GF)----->ALCATEL-4400.
When same one from the pstn call to a DN on alcatel 4400 the alcatel 4400 responds to a setup from the callmanager with a CALL-PROC folowed by a ALERTING with PI=8 and folowed by a PROGRESS with a PI=8. With the alerting with PI=8 the pstn does not open the audio channel. The alcatel 4400 as a feature (connect on progress) that generate a connect message in the presence of a progress message. On the cisco does any one knows a equivalent feature on the cisco side to send the connect message to the pstn based on the receiving progress from the alcatel.
Many thanks
przemzambrzy Thu, 03/12/2009 - 05:03
Hi all,
I have similar problem. Does anyone find a solution?
Thanks in advance
aherraez77 Tue, 03/24/2009 - 06:14
Hello:
Have you tried to use this comand in the GW cisco?
In the pots outbound dial peer:
progress_ind progress enable 8
patcbr600 Tue, 03/24/2009 - 08:00
Hi all,
The only way to resolve the issue was using
a a feature "connect on progress" on alcatel side.
