get arp table on ASA using snmp
Sep 4th, 2008
What is the way to get the arp table on an ASA using snmp? I tried doing an snmp walk on .1.3.6.1.2.1.4.22, which works on a Cisco router, but got nothing.
Mike
Overall Rating: 3.5 (2 ratings)
hadbou Wed, 09/10/2008 - 08:41
To view the ARP table, use the show arp command in privileged EXEC mode.The display output shows dynamic, static, and proxy ARP entries. Dynamic ARP entries include the age of the ARP entry in seconds. Static ARP entries include a dash (-) instead of the age, and proxy ARP entries state "alias."
suschoud Wed, 09/10/2008 - 09:21
what you are trying to accomplish in the ASA is not supported.
You already has configured SNMP on the ASA but it seems that there is no MIB that supports
to extract the ARP table and send it to that tool.
Here you have the link with the SNMP configuration and also there is a section that
indicates all the MIB supported, unfortunately there is nothing to obtain the ARP table.
http://www.cisco.com/warp/public/110/pixsnmp.html
there is nothing supported in version 7.x either, Checked the MIB
but nothin related with that.
http://www.cisco.com/en/US/products/ps6120/products_configuration_guide_chap
ter09186a0080565912.html
Please rate if helpful.
Sushil
