Redistribute RIP into EIGRP network
Answered Question
Sep 4th, 2008
Hello everyone, I am building my own network at home and need some guidance
could you tell me how to redistribute RIP into EIGRP, the network at home I set up is using a the 10.10.10.0 255.255.255.0 IP and subnet and on the internet facing side of the router it uses RIP on network 192.168.1.0 255.255.255.0 the default gateway for the internet is 192.168.1.254, I am using NAT as well on the internet facing router to translate the 10.10.10.0 to 192.168.1.1. How can I redistribute the networks learned by RIP into the EIGRP network?
Any Thoughts???
Correct Answer by Jon Marshall about 8 years 9 months ago
Shane
EIGRP can use 5 different metrics when it selects routes although by default bandwidth and delay are the only 2 used.
See attached link for more details -
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a00800c2d96.shtml#eigrpbasics
Jon
Correct Answer by Richard Burts about 8 years 9 months ago
Shane
Redistribution of RIP into EIGRP is not so difficult. The main thing to remember is that when you redistribute into a protocol you usually need to define a default metric. So redistribution of RIP into EIGRP might look something like this:
router eigrp 1
redistribute rip 10000 100 200 50 1500
This will redistribute the routes learned by RIP into EIGRP.
Rick
Overall Rating: 4.3 (4 ratings)
Correct Answer
Richard Burts Thu, 09/04/2008 - 09:00
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Shane
router eigrp 1
Rick
Correct Answer
Jon Marshall Thu, 09/04/2008 - 12:31
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Shane
Jon
shane.kearney Thu, 09/04/2008 - 12:28
Hello, what does the input 10000 100 200 50 1500 mean in the command
Giuseppe Larosa Fri, 09/05/2008 - 00:39
  • Hall of Fame,
    Founding Member
hello Shane,
all those parameters are there to provide the metric components to calculate the seed metric: the metric that EIGRP will associate to prefixes imported from RIP in this case.
EIGRP requires an explicit configuration of the seed metric you can do it in a separate line command with default-metric 10000 100 200 50 1500 or as Rick suggested in the redistribute command.
The difference is that using default-metric it can be used by multiple redistribute statements.
Without defining a seed metric no RIP prefix would be imported in EIGRP so it is a necessary step in redistributing into EIGRP.
Hope to help
Giuseppe
Richard Burts Fri, 09/05/2008 - 04:33
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Shane
As Jon and Giuseppe have pointed out EIGRP needs 5 parameters as part of its route advertisement and calculation of metrics. For redistributed routes you typically need to supply those 5 parameters. If you are interested in the meaning of the parameters here they are:
10000 represents a figure for bandwidth
100 represents a figure for delay
200 represents a figure for reliability
50 represents a figure for load
1500 represents a figure for MTU.
It is not particularly important what specific values you use. I like to use figures that would be typical for a moderately attractive route. I have seen configs where people used a default that represented a very attractive route (very high bandwidth, very low delay, very high reliability, very low load) and that works also.
Rick
