TACACS+ & local account Concern
Sep 4th, 2008
Does the folllowing lines means that initially the authentication would be ACS-Server and incase ACS-Server is down then it would allow router-local username/password
aaa authentication ppp default group radius local
aaa authentication login default local
Premdeep Banga Thu, 09/04/2008 - 10:13
  • Gold, 750 points or more
If you are doing PPP connection (Dial-up), then true.
If you are trying to log into device for management(telnet/ssh), then no, then following command will be evaluated,
i.e. only local database will be checked.
Prem
Please rate if it helps!
Amin Shaikh Thu, 09/04/2008 - 14:46
thanks Prem for your reply.
I would be logging into device for management (telnet/ssh)
So whats required to fillfull my requirement...
Premdeep Banga Thu, 09/04/2008 - 14:50
If you are using radius as the protocol,
radius-server host key
aaa authentication login default group radius local
If using tacacs+ as the protocol,
tacacs-server host key
aaa authentication login default group tacacs+ local
ACS needs to be configured accordingly.
Prem
Amin Shaikh Fri, 09/05/2008 - 04:43
Thanks Prem..
I need to understand if the ACS Box is not reachable then how could I authenticate based on the following commands -::-
Premdeep Banga Fri, 09/05/2008 - 04:48
Have a user on local device, something like,
username admin privilege 15 password pa55w0rd
Then when Tacacs server is not available, you can log into device using the above created user account on the device.
Prem
