normal output from VPN 3002?
Sep 4th, 2008
I have a remote access vpn tunnel established through a 3002 hardware client. Everthing is working fine for the most part. It's only at sporadic times that the remote users application will time out, maybe due to network connectivity.
Looking at the syslogs from the 3002 it is constantly returning these messaages...
Is this normal, or does it seem like there may be an issue?
2008-09-04 14:30:03 Local7.Debug 10.0.0.1 1570: 2008 Sep 04 14:29:57.790 EDT -4:00 %IPSECDBG-7-18: RPT=190: 24.28.48.42: Xmit IPSEC-over-UDP NAT keepalive packet: success
2008-09-04 14:30:04 Local7.Debug 10.0.0.1 1571: 2008 Sep 04 14:29:59.850 EDT -4:00 %IKEDBG-7-0: RPT=777: 24.28.48.42: Group [24.28.48.42] sending notify message
2008-09-04 14:30:04 Local7.Debug 10.0.0.1 1572: 2008 Sep 04 14:29:59.850 EDT -4:00 %IKEDBG-7-0: RPT=778: 24.28.48.42: Group [24.28.48.42] constructing blank hash
2008-09-04 14:30:04 Local7.Debug 10.0.0.1 1573: 2008 Sep 04 14:29:59.850 EDT -4:00 %IKEDBG-7-0: RPT=779: 24.28.48.42: Group [24.28.48.42] constructing qm hash
2008-09-04 14:30:04 Local7.Debug 10.0.0.1 1574: 2008 Sep 04 14:29:59.850 EDT -4:00 %IKEDBG-7-0: RPT=780: 24.28.48.42: SENDING Message (msgid=d6ad7f80) with payloads : HDR + HASH (8) + NOTIFY (11) total length : 80
Overall Rating: 5 (1 ratings)
JORGE RODRIGUEZ Fri, 09/05/2008 - 05:05
  • Green, 3000 points or more
This is normal, BTW you have login in Local severity 7 which is debugging meaning you will literally see almost every single traffic at this login level, you may want to change that level to informational, debugging is helpful when troubleshooting but not necessary under normal operations.
Rgds
Jorge
